Home > Puma (Tdci) > Puma Reverse Light
Ricky Chianese
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
Puma Reverse Light
Anyone out there upgraded their standard reverse light to give more light output?
There are some 15W HID retrofit kits available but not sure if they can be made to fit. Why do today what you can put off until tomorrow?
Post #124702 17th Feb 2012 12:32pm
XS Pete
England 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Yes, I have. I put a 5W Cree LED in mine and the improvement is good. Mine is one of these: http://www.ebay.co.uk/itm/300551786533
Pete
Post #124708 17th Feb 2012 1:04pm
Grockle
Pete
Thanks for the info,just ordered one Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #124720 17th Feb 2012 3:56pm
XS Pete
It's pretty good Grock. I don't think you'll be disappointed.
Pete
Post #124793 17th Feb 2012 9:02pm
LR90XS2011
XS Pete
ive ordered one as well DEFENDER 90 TDCI XS,
Post #124797 17th Feb 2012 9:10pm
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
My reverse lamp is hooked up to my work light, both lamps light my rear up beautifully!! Rolling with laughter 2009 XS 110 Utility Stornaway Grey
BAS re Remap, BAS Turbo, BAS Spec Modified Airbox, Twisted Side exit Decat Exhaust, Allisport Cooler and Hoses, OME Sport Shocks, Kangaroo Paw Discs.
2001 Discovery II
Porsche Speedster Replica 1956ish
Post #124800 17th Feb 2012 9:12pm
T1G UP
i want a rear work light / reversing light WITHOUT putting extra holes in the body....any ideas
Post #124818 17th Feb 2012 9:34pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Mag-mount? [you can place a steel plate behind panel]
Or suction mount ... both common worklamp fittings Smile Guns and Landrovers .... anything else is irrelevant.
Post #124822 17th Feb 2012 9:36pm
XS Pete
Just for info, the reason I particularly went for a USA made Cree LED lamp, was because I bought one of their maglite upgrade kits for one of my 'D' cell maglites and was massively impressed Thumbs Up
Pete
Post #124824 17th Feb 2012 9:39pm
Bigfog: AFAIK unless your set up includes a switch it's illegal to have rear work lights triggered by selecting reverse gear. Correct me if I'm wrong Thumbs Up
TIG: How about magnetec based worklamp? I think D44 do one. Only problem would be: A. theft and B. routing the cable. Maybe routed under rear door seal providing that it doesn't get crushed or damaged! Thumbs Up
Post #124825 17th Feb 2012 9:39pm
That is correct. So, I suspect, is a more powerful bulb in the existing light. In the grand scheme of things though, there are far worse lighting related crimes on the roads every day that go ignored (fog lights, blue lights, aftermarket HIDs, etc) so I can't see overly bright reversing lights being at the top of anybodys 'to prosecute' list. An isolating switch on a worklight isn't a bad idea though.
Mount it inside one of the small rear windows?
To be honest, mounting it externally isn't too much of a problem - use a CB aerial gutter mount. Getting the power to it is the tricky part. You might be able to thread a cable through the door seal, but that seems a bit too Heath Robinson for me. So, short of something powered by induction, you'll need a hole for a cable. Darren
Post #124846 17th Feb 2012 10:08pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Have a look at a shooting suppliers, I saw a pretty impressive suction mount shooting light on the stand next to mine at the Midland Game fair. Works off a 12v socket and was remote control, don't know how good the mount was but should do the job Id have thought.
Supposed to be for spotting bunnies etc but would work just as well as a rear spot.
Dj 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #124876 18th Feb 2012 12:17am
leeds
Lightforce do a suction mounted 30watt stubby light, so that is a possibility.
There are various watertight seals for taking wiring through the roof etc. Have just picked up a sample for taking up to 5 cables through roof.
If you have a roof rack fitted cabling can be run along rack to front down snorkel and under bonnet or down rear access ladder.
Brendan
Post #124882 18th Feb 2012 1:27am
Brendan[/quote]
Great suggestions! Never thought of the rear ladder myself.
Post #124938 18th Feb 2012 12:50pm
T1G UP
don't want a rack or a ladder. I'm thinking mounting off the wheel carrier..so it raises above the wheel and shines down.
Post #124944 18th Feb 2012 1:26pm
