![]() | Home > Maintenance & Modifications > Drooping wings |
| shorty Member Since: 31 Oct 2008 Location: Hillcrest, Kwa Zulu Natal Posts: 160
Hi guys. I got my brand new replacement 90 last week from LRSA. When I was fitting the wing top checker plate and headlight grills this afternoon I gavemyself I slight heart attack. As usual once I fit somthing I like to stand back and admire the view but was shocked to see that the headlight grill was skew. How could this be? I measured,re measured and measured again before drilling. I pulled out the measuring instruments againand was quite shocked to find that the entire wing has been mounted skew. Is this a job I can do with not to much effort or should I tell LR to fix or am ibeing fussy? I'll post some pics on Monday. Land Rover's don't leak oil, they simply mark their territory!
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711
Yep take it back
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
I bet it is the left wing. Take it back for sure. Puma 110" SW
Cheers!
I'll take it back in the morning. It's the drivers side wing that droops the worst ( rhd ). Land Rover's don't leak oil, they simply mark their territory! |
let me know if you can notice it?
Click image to enlarge Click image to enlarge Land Rover's don't leak oil, they simply mark their territory! |
| bustduster Member Since: 13 Apr 2009 Location: UK Posts: 14 |
Even after ten pints my droop wouldn't be as bad as that!!
| Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266
It is noticeable. 2.4 90 XS
LR have loaned me a disco and sent the defender to the body-shop. Does anybody know if its a case of bending it into shape with force or will they have to remove and refit? is it riveted on or spot welded? Land Rover's don't leak oil, they simply mark their territory!
Loosen the mounting bolts and realign should be all it needs 2.4 90 XS
hopefully it will be done in a jiffy then!!
just out of interest. Does anybody have a haynes exploded view of how a front wing is mounted or any other similar illustrations. Im interested to know what the butchers (panel beaters) are up to?? Land Rover's don't leak oil, they simply mark their territory!
| NoDo$h Member Since: 18 Aug 2007 Location: Buried in deer guts in Dorset Posts: 972
LHS on ours has a slight droop, although not as bad as that. I put it down to the charm of owning a Defender.
I managed to get the roof back on straighter than when it came out of the factory after we sold the soft top earlier this year. I suspect I might have taken a little longer over it than two hairy brummies in the factory though
54 Freelander modded for mud 2008 D3 SE 2010 90 XS SW 1978 88 Series 3 undergoing surgery with a new owner 2007 90 County Truck Cab - gone 2006 D3 SE - gone 2004 Freelander Sport - gay 1999 Disco V8 ES rotted to bits |
| d j hutton Member Since: 30 Jul 2009 Location: Dorset Posts: 1044
Just had mine straightened our on first service, wasn't quite as pronounced as this one, but is now spot on.
So it can be easily sorted by the dealers, a bit of arm twisting may be required. Don't take any notice of the 'they are all like that sir' I didn't see any in the land rover promotional shots that were droopy, although nearly all of the new ones in the showroom/display were out to various degrees. Take it back and be nice - that seemed to get a good result. DJ 1989 200tdi 90 csw 2011 110 usw Orkney grey Buy British 🇬🇧 Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html |
| SteveT247 Member Since: 21 Feb 2011 Location: Central Posts: 491
Why does this only seem to affect Puma's? I didn't think they were built any different to Td5's, Tdi's, etc, etc.
