Home > Puma (Tdci) > Loss of power
Page 2 of 3 <123>
johnnyturbo2002
Spain 2008 Defender 110 Puma 2.4 CSW Java Black
This has happened to me twice (or maybe 3 times)in two different kinds of weather...1st (2nd) in summer with about 30C and the other with 13C, both pulling a slight hill loaded with wife and kids...felt liketurbo cutout and I was left with very little power. No lights or warning lights, nothing. Pulled over switched off and on again with in 30 seconds and it was fine...told my dealer about it today and she looked blank as if never heard of it before...I'll love to know what the problem is/was if you guys figure it out. 2008 Defender 110 60 year Edition (sold unfortunately)
IN the hunt for another Puma for the wifey!
2008 Kia Sorento LX 😁 2.5crdi
Post #123660 13th Feb 2012 4:24pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Strange this, the same happend to me on Sunday. It is booked in at the end of the month and this is what I have told them what happend.
11. Last Sunday I was driving on the motorway at around 65-70, mph when the vehicle suffered a total loss of power. I pulled onto the hard shoulder and at about 30mph it suddenly started to run as it should (temp gauged showed normal). Then about 5 miles up the road it did it again, I again pulled onto the hard shoulder and again it suddenly started running properly (temp gauged showed normal). On the third time it did it I notice that briefly the temp gauge shot up to hot for about one second then fell to normal again. I pulled onto the hard shoulder and let the engine cool for 10 minutes and then drove off again and there were no further problems. If the engine was overheating the gauge only showed this briefly on one of the three times the engine cut out.
When I spoke to the service manage and told him I have no mil light he said it would not have logged any codes and had never heard of this before (well at least he didn't say they all do that").
Post #123666 13th Feb 2012 4:43pm
fekete
United Kingdom 2007 Defender 90 Puma 2.4 HT Bonatti Grey
Boy, exactly the same when i came of the motorway it was better at say 30 but turned it of for 10 mins and its been fine since...it would be nice to know what as coursed it if the dealer finds anything let us know Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #123673 13th Feb 2012 5:18pm
The Boy
Happy to pass anything learned from the dealers but I am not holding my breath. But if you do see a headline stateing that hell has frozen over you know who to ask. Thumbs Up
Post #123675 13th Feb 2012 5:22pm
Eduardo
Hummm,
Same to me with high temps and long trips. Looks like a high temp protection issue, but not sure.
As soon as you have some news please post it.
Cheers Eduardo
Post #123688 13th Feb 2012 6:25pm
The Boy
What has confused be is that I thought if there was an overheating issue the AC fan should also cut in but in this case when I stopped it was not running.
Post #123689 13th Feb 2012 6:27pm
Lorryman100
A couple of my thoughts/ramblings on possible causes on the electrical side of this problem?
The ECU protocol for high coolant temp is for the fan to run continuously whether the coolant is hot or cold. The sensor used by the ECU to monitor coolant temp is the CHT sensor (cylinder head temp) which is located at the rear of the engine at the coolant manifold junction. The ECU uses this sensor to do fueling calculations, limit engine operation if engine coolant temperature becomes too high, cooling fan operation and glow plug activation time. If this sensor is faulty the ECU defaults to a stored temp of 80C and runs the cooling fan continuously which can lead to: difficult cold start, difficult hot start, engine performance compromised and temperature gauge inoperative or inaccurate reading.
The next sensor would be the MAP sensor which is located on the Intake manifold. This controls active boost which in turn controls the angle of the variable vanes within the turbo which are controlled by the turbo modulator acting on information received from the ECU which in turn acts on the information received from the MAP sensor. So if the MAP was faulty the ECU reverts to a default pressure of about 1013 mbar which in turn would render Active boost control inoperative and start throwing out black smoke due to over fuelling (Altitude compensation inoperative), so it would feel as if there was no power when you pushed in the throttle pedal. This sensor is easy enough to remove and clean so this would be the first thing I would do.
The turbo modulator plug and harness have been the subject of a recall notice due to the harness suffering from heat and vibration damage. There has also been a case on here of the harness plug being at fault for power loss due to a couple of broken wires, CRJ IIRC. A visual inspection should let you see if the issue lies there. And while you are there give the control bar a pull and see if that moves freely without any binding/stiffness.
The MAF sensor if faulty will just make the ECU revert to stored values and would increase fuel use and turn on the MIL if knackered, but should not cause any sudden drop in power issues?
TPS (Throttle Position Sensor) is part of the accelerator pedal and is a complete unit so all you could really check is the plugs for water contamination?
Though the best way to find out what is causing this issue would be to plug in a diagnostic tool and check the live engine data to see what is going on. A scangauge set up to monitor the MAP, CHT and TPS would either rule them out as the cause or confirm the problem sensor. Even unplugging the above sensors and coating the pins and plugs with an electrical contact cleaner may clear the fault?
HTH Brian
Post #123698 13th Feb 2012 8:10pm
fekete
Thanks for all the info Brian and taking the time to Write it.....Also giving us a bit more knowledge on the faults were getting...top man Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #123722 13th Feb 2012 9:04pm
The Boy
What he said.
Thanks Brian you're a star Thumbs Up
Post #123729 13th Feb 2012 9:25pm
Lorryman100
Embarassed Embarassed Thumbs Up
Another thing worth checking if all of above pans out OK is the VCV (volume control valve) located in the fuel pump as this is responsible for metering the fuel from the low pressure to the high pressure side of the pump and onto the fuel common rail. Because of its location it might be worthwhile checking the harness and giving the plug and pins a coating of electrical contact cleaner. Again this sensors actions can be added to the list of scangauge monitored sensors, the gauge being the FPr (Fuel pressure at rail).
Post #123742 13th Feb 2012 9:46pm
Lorryman100
Just incase anyone is wondering how the MAP sensor gets dirty as it is on the clean side of the air filter?
I think it is because the recycled exhaust emissions from the EGR enter the intake manifold via the gas transfer and mixer pipe which is adjacent to the MAP sensor along with minute contamination which passes through the air filter and builds up over time. I would be curious to know if anybody with a performance oiled air filter notes any oily/grungy contamination on the MAP?
You can see it in the below pic. Please ignore the red writing as this pic was done to show the total removal of the EGR system by using the new Entreq replacement manifold without the gas mixer pipe and removing the EGR cooler and blanking the exhaust manifold. But as I now have the EGR closed 100% of the time by the Alive remap I don't see a need to completely remove the EGR system. Thumbs Up
Brian.
Post #123756 13th Feb 2012 10:14pm
wslr
Quote:
'Just incase anyone is wondering how the MAP sensor gets dirty as it is on the clean side of the air filter'
They all do this over time, which is what is so ironic about the idea of the system to start with. As the sensors get dirty, they stop the engine working efficiently. Also, don't forget the areas around the inside of the inlet get covered in an oil/soot mixture (anyone having removed and EGR unit will have seen it).
Freelander Td4 M47 engines are really bad at this. The entire inlet plastic inlet pre-manifold starts silting up on the inside up to the point where the engine won't run properly because it can't breathe.
Not wanting to worry anyone with a hypotheses, but have you thought that adding 2 stroke oil or using poor fuel may actually contribute to this. Just an hypotheses, so no shouting please. Wink
Anyway, I expect the dealer will either download latest Powertrain ECU software, or run the EGR/Turbocharger diagnostic to see if the readings are correct for fast idle and idle. This also tests the MAF. However, from your description it sounds more like an electrical (loom/multi-plug/ECU/relay) issue really, especially if no DTC's are stored.
Post #123791 14th Feb 2012 12:01am
jav-uk
England 2014 Defender 110 Puma 2.2 SW Alpine White
Bow down Lorryman Bow down
I have had an ITG filter fitted for past 1000 miles. Will check the MAP for oil and advise.
Filled up with Shell diesel but only did short journey's over the weekend, all has been okay for me since.
I am hoping my issue was related to dodgy fuel. I vowed never to use Morrison's fuel after the bio fuel fiasco
but I read somewhere their fuel no longer has bio added and have been using them occasionally because its cheaper.
I also have a vague memory of a thread about water contamination in the fuel line causing power surges..... Paul
Pondering a New 90 Commercial
2020 Evoque
* 2014 110 SW JE Stage 2.
*2010 110 Utility. JE Stage 2.
*2007 110 SW
*2003 90 JE Stage 2.
*2000 90 SW
If its not leaking it ain't full.
Post #123796 14th Feb 2012 12:20am
BIGFOG
United Kingdom 2009 Defender 110 Puma 2.4 USW Stornoway Grey
I've had an ITG filter for about 60000 miles and have checked the MAF sensor before for deposits and even sent it back to Pete Bell when he did a forum analysis. There was a little contamination on the sensor, but nothing horrendous and replacing it with the new one that Pete supplied made no difference to the running of the engine - NB I also use the 2 Stroke trick and will not go back!
I do however have serious doubts about diesel quality and where possible only use Shell or BP. It seems that 50% of the time I go elsewhere the engine runs like a dog.
I also use a diesel cleaner like redex every now and then which always seems to pick up the performance an mpg. 2009 XS 110 Utility Stornaway Grey
BAS re Remap, BAS Turbo, BAS Spec Modified Airbox, Twisted Side exit Decat Exhaust, Allisport Cooler and Hoses, OME Sport Shocks, Kangaroo Paw Discs.
2001 Discovery II
Porsche Speedster Replica 1956ish
Post #123807 14th Feb 2012 6:26am
CRJ
Denmark 1991 Defender 90 200 Tdi ST Alpine White
Hi
Just a short question about the actuator arm - should I be able to move it up and down - or just see that it moves freely in the joints? Mine moves in the joints - but I cant move it up or down at all Question
Regards
CRJ 88 Ser. 3 1980 -sold
Puma 130 - 08- sold
90 200tdi 1991 - sold
88 Ser. 3 1977 200 TDI
110 CC 2003
Post #123809 14th Feb 2012 6:44am
Page 2 of 3 <123>
