![]() | Home > Technical > Spring Part Numbers: Which position? |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
HD 110 front springs and standard 90 rear springs are the same item [225 lbs rated
Yes they are handed ... not that it makes a great difference lol You can fit them to the front of a 90 cos guess what? ... HD 90 front springs are the same item too ![]() |
How many springs have you been given? The thing to bear in mind is that if you fit these springs to the front they will be HD (bit of lift and firmer ride) and on the rear they will be standard duty. So the next question is what other springs are you fitting with them? John http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2037 ![]() ![]() |
I have 2 of each.
Does that mean they are incompatible with each other? 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Fitting HD fronts and standard rears is the usual arrangement if you have a winch on the front, to offset the extra weight. If you don't have one then yes, for all practical purposes, they're incompatible. Darren
