![]() | Home > Technical > Heated Breather Modification LTB00196 for arctic regions |
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
I have contacted my local dealer today, so far they have not come across the problem. I have send the bulletin number in LTB00196 and they are now contacting LR Norway... fingers crossed
| mermoto Member Since: 21 Sep 2011 Location: Essex Posts: 326 |
Quite an interesting problem this since it has been recently highlighted on the Mudrut Arctic trip. Where exactly does the end of the breather come out? Can it be relocated to avoid wet air getting in and freezing? or is the damp actually being vented by by the Puma engine?
Mermoto |
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
If interested download the bulletin https://files.me.com/daniele.gardellin/5czjyu Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
nice one Daniele
I have also heard back from the dealer .. trying to get it fixed on warranty |
So reading the bulletin do I take it that the heater element in the breather hose is only working when the engine is running? does this mean when the engine is cold (ie standing over night) that ice can still form in the hose in severe conditions? Mermoto |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
Is that a uk dealer or the one you bought it from? Russell 2011MY 110 XS USW Black |
the defender is tested to -40c ** updated ** The breather pipe runs from the rocker cover (just behind the pasty warmer) to the back of the airbox unit. From what I have read, the problem seems to occur due to the cold air in the airbox meets the warm air from the breather pipe, and ice forms - eventually blocking the breather and causing pressure in the engine. D44 sell a heater kit to fix the problem in the form of an inline heater unit. It's wired into the heater terminals, so the in-line breather heater is activated when the heater is on in the vehicle. (makes sense) Just to add, I have a MY2010 Swiss 110 and it has not got the modification as standard. |
| Denis Member Since: 28 Dec 2010 Location: prairie Posts: 58
Here is mine breather heater - it is consists of relay, cable and in-line heater itself. The heater itself is under the pipe unsulation - I marked the place.
Fitted as standard, 2010MY. I fitted pipe insulation on breather for additional confidence Also for cold climate you need to fill the gap under the bonnet, because breather is almost exactly facing that gap. Click image to enlarge Puma 110 |
| T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101
remove the breather and put a small K&N filter instead? As we have fresh engines they should breath heavy anyway so a small filter will be suitable.http://www.knfilters.co.uk/search/universal.aspx
thanks Denis, looks like a good idea to insulate the pipe too. Do you use the LR in-line heater or something else ? the LR fix wires the in-line-heater into the cabin heater electrics, so that the heater is on when the cabin fan/heater is running .. how have you wired yours ? |
BPman
Heater was in place when I bought truck in 2010 from dealer, it is genuine LR and yes it is wired to cabin heater through relay on photo. There were many Puma Defenders in Russia in 2007-2009 with oil off engine (sorry for my english Cheers Puma 110 |
thanks Denis ... I missed the bit "Fitted as standard, 2010MY"
- must be fitted to Russian and Scandinavian models do you know of any other changes on your model for cold climates ? cheers bp |
Yes I know! Now other changes! Other small modifications are self-made: 1. self adhesive rubber sealant (for doors and windows) - on perimeter of bonnet 2. engine blanket - is merely put on all engine bay 3. radiator muff thats enough for -30C - tested have some photos - if someone interested cheers Puma 110 Last edited by Denis on 12th Feb 2012 5:42pm. Edited 1 time in total |
engine blanket - some non flammmable material
| All times are GMT |
