![]() | Home > Maintenance & Modifications > My Defender to sit for extended period - how often to drive? |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
In a ideal world then you should drive every day but once a week is fine if its kept in a garage. For long term storage, i would personally say anything over a month i would put it on axle stands and connect a maintenance charger to it to keep the battery healthy. Changing the oil and gearbox fluids would also help and making sure its dry before parking up would also help. I would also put some rat and mice traps and/or poison down as you dont want the little
![]() Pete. |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2506 ![]() ![]() ![]() |
Pump up the tyres so they do not deform (unless you use axle stands). Puma 110" SW
great reply Pete, in addition if stored in a garage I would leave one of the windows down about 1cm to allow airflow If you are leaving it for more than 2-3 months, there are companies who can store your vehicle and run it once a month on a private road - google classic car storage |
eutek Member Since: 03 Mar 2009 Location: High Wycombe Posts: 586 ![]() ![]() ![]() |
Thanks guys...
I won't have the luxury of a garage, I'll just have to leave it in my driveway or rent a space in London. ![]() I'll be driving it about once a week at the most it seems. I literally won't be around during the day to drive it, and the distance between my house to the station is so short that it isn't worth driving - it is about a mile. Not enough time for the 110 to properly warm up! |
