![]() | Home > Maintenance & Modifications > ACF-50 - temperature restriction? |
No but keep the tin inside for a bit or warm it up because its thixatropic with temperature (ie it gets thick
![]() It goe much further if you spray a bit on a rag then wipe it on rather than spray direct a lots is wasted that way. |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2682 ![]() ![]() ![]() |
I've just ordered a "quart" of ACF-50 in liquid form for that very reason.
I can put it into a trigger-pack if I want to spray it...or... ...paint it on to prevent overspray (i.e. near brake disks, or near the aux drive belt in the engine bay) ![]() |
Still best when its at room temp Martin
bolampau Member Since: 06 Jan 2012 Location: Lincolnshire Posts: 100 ![]() ![]() ![]() |
Thanks Folks,
will start spraying the car tomorrow, if the weather holds?! |
You can put it on in the cold without any issues as long as the liquid is a decent temp when you start. But by spraying you'll go through a can in no time at all, believe me, I've made that mistake
Thanks BigMike, good advice, so will spray onto a rag. Maybe a silly question, but does it wash off when you clean the car? |
Not a silly question at all, but no, it doesnt. If you scrub it it will come off, but if its just water not under very high pressure it's fine. You'll see the water beading on the areas you've put it. On a Defender, us it on all bolt heads, wipe the rear crossmember with it, door locks, wheel nuts, wheels, in fact any area there is any kind of exposed ally or steel at all. Front bumper too, engine bay, hinges, anywhere you think really. Also good is to wipe window surrounds with it. It makes them look good and keeps the water away.
You really only need to do it a couple of times a year. |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
Bearing in mind that this stuff was developed by the Lear Corp in Canada for use inside aircraft box sections and behind skins, and the outside airtemperature at altitude reaches -56C, I don't think the cold temperatures we're experiencing at the moment are likely to affect its properties.
Warming it up though does make it a lot easier to get out of the aerosol or pump dispenser. Pete |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Mine came through today, ordered on Monday ![]() ![]() |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
The pumps can be temperamental - just like me really
![]() Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Jeez, if the pumps are that bad - stick to aerosols ![]() http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
I used the aerosol today and it was a doddle.
It reminded me of gun oil spray that I used years ago. Thanks to everyone for their advice, Paul |
