Home > Technical > Interior Light Fuse
Merlin
Interior Light Fuse
I’ve managed to blow the fuse while I had the rear interior light out, yes I know I should have been more careful, but now I can’t find the right fuse. Oddly the radio has stopped as well. Any ideas?
Merlin
Post #62524 6th Mar 2011 7:50pm
daviec1
United Kingdom 2005 Defender 110 Td5 DCPU Bonatti Grey
yeah I shorted mine too - bumped the pliers against the fixing plate - sparks, smoke & blown fuse.
From memory it is one of the ones in the interior fusebox (in my TD5 it was anyway) - same one as radio, for some daft reason.
Of course, you better know your radio code or you are going to have a problem.... 2001 TD5 110 DCPU in Bonatti Grey
Post #62537 6th Mar 2011 8:29pm
MK
dashboard or under one seat Puma 110" SW
Post #62538 6th Mar 2011 8:29pm
james975
Scotland 2000 Defender 90 Td5 HT Epsom Green
Under the drivers seat .
Post #62681 7th Mar 2011 8:31pm
Martin
Site Admin
Fuse 30 in the dash fuse box - 10A rating  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #62712 8th Mar 2011 1:25am
LR90XS2011
once again this forum proves invaluable, just blew my fuse fitting LED interior lights, couldnt find which fuse and the manual was no help, but the answer was here DEFENDER 90 TDCI XS,
Post #122719 9th Feb 2012 5:46pm
Easily done Whistle You're right that the manual isn't any help, but the fuse descriptions are printed on the inside of the fuse box cover under the dash. Darren
Post #122722 9th Feb 2012 5:51pm
Jim_Bean
I've done the same - blown the fuse.
Is this the right replacement? The red 10A one?
http://www.ebay.co.uk/itm/20pc-Replacement...4897.l4275
Post #299370 16th Jan 2014 5:53pm
Likeomg
i also blew the rear light fuse, but my radio still works? haven't figured out how to fix yet..
Post #299380 16th Jan 2014 6:30pm
Waldo
Simple way... Pull your fuses one by one and check if they're blown
From memory it's in the bank on the bottom left of the dashboard fuse box. Defender 90 XS TD5 (03 Reg)
Post #299388 16th Jan 2014 7:06pm
DRW58
Scotland 2001 Defender 90 Td5 SW Epsom Green
Did the same! under drivers seat TD5 pull all the fuses till you find the right one! Simplez DRW I built a garage for my Mini
With a place for everything and everthing in its place.
Ten years down the line there's a Mini in there somewhere, and Censored all's where it should be!!!! Ho hum
Post #299405 16th Jan 2014 8:18pm
Jim_Bean
I guess I just need a new 10A fuse?
They're all the same size right?
Post #299431 16th Jan 2014 9:50pm
Yes, they're all the same size. Darren
Post #299445 16th Jan 2014 10:22pm
Jim_Bean
Excellent thanks!
Post #299447 16th Jan 2014 10:25pm
Jim_Bean
OK - I checked all the 10A fuses and they seemed fine. I don't want to start pulling all the fuses in case I upset the immobiliser or alarm.
Can anyone let me know which of these is the interior lights fuse? (The radio doesn't work either!)
The fuse layout diagram isn't much help.
Post #299557 17th Jan 2014 11:22am
