![]() | Home > Puma (Tdci) > Poor performance |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Please keep is updated with the results. Brian |
| CRJ Member Since: 12 Mar 2011 Location: Sealand - Denmark Posts: 253
Short update - did 150 km today without any problems - pulls great from 1500 rpm.
Regards CRJ 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
Still no problems - gone from about 500 km on a tank to about 600
Fault codes now P1402 P0234 P0100 P0623 Did think about cleaning the ECU connections once more - any recommendations on how to? Regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
Torque is also back - clutch is gone today
What is the easiest way to remove gearbox - seat base out - or from underneath ? Regards Christian 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
Regarding clutch change - I ordered a new one today - was told that normally one does´t change the release bearing as it is part of the slavecylinder - I never changed a clutch without changing the release bearing so I ordered a new slave cylinder kit as well - anything special about changing it?
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2512
It is at lot of work. A bit tricky to get the belhousing-to-engine bolts. You may need a cardanic joint/extension. To remove the exhaust/cat is also a PIA. Tip: be careful not to break the protruding plastic tubing from the slave cylinder. Puma 110" SW
Short update - clutch changed. Car is doing great - no limp mode and pulls great from 1500 rpm all the way to 3200 rpm.
Regarding poor connections can anyone recommend something to clean connections with. Am planning to go over all connections in the engine bay. 88 Ser. 3 1980 -sold Puma 130 - 08- sold 90 200tdi 1991 - sold 88 Ser. 3 1977 200 TDI 110 CC 2003 |
Christian, I use this stuff from CPC Farnell. K9F on here is a sparky and recommended it.
http://cpc.farnell.com/1/1/31082-electrolu...olube.html Brian. |
| All times are GMT |
