Home > Technical > frost's windscreen sealant |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10367 |
It stays soft for a while, you can squeeze it out by pushing the rubber.
4th Feb 2012 12:16pm |
boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48 |
Ok good, was worried after i sealed it the temperature outside dropped well below freezing.
4th Feb 2012 12:31pm |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 4990 |
Yes, this is the stuff you want as it does stay flexible where not exposed Old style window rubbers shrink a bit under sunlight (and can crack eventually!) and the whole frame can flex depending on the car and application so this is why using the stuff that doesn't dry out is what to use rather than rock hard cement glues used in modern motors which you need as the window is a structural part of most modern vehicles
4th Feb 2012 3:05pm |
