Home > Puma (Tdci) > Winter leak
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Winter leak
I was overoptimistic about behaviour of my car in extremely low temperatures.
She started-up nicely today in the morning at -26'C, only to make this for me:
Any ideas what may be leaking? I will have a chance to look closed after the weekend.
It is just left from the notorious vacuum pump, but the pump itself looks all right.
Have a nice weekend! Janusz
www.yahodeville.com
Post #120897 3rd Feb 2012 4:28pm
bob neville
Fuel pressure pump is next to the vacuum pump.
Mine was leaking, not as bad as that, and repaired.
2013 Defender 90 CSW - sold
Post #120903 3rd Feb 2012 4:57pm
Grockle
crankshaft front seal ? 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #120904 3rd Feb 2012 5:04pm
any news ? have you been to the dealers ?
please keep us updated Thumbs Up
Post #120975 3rd Feb 2012 7:30pm
yaho
I will take a look on Monday. Updates will come. Janusz
www.yahodeville.com
Post #121150 4th Feb 2012 9:38am
yaho
So, there is a leak at the crankshaft seal.
But is ceased and does not leak anymore Confused
As it only happened at -26'C and heavy load (towing frosted cheerokee Smile ) I suspect the sealing was not functioning properly.
I will look at that place regularly and see how it develops. Janusz
www.yahodeville.com
Post #122048 7th Feb 2012 12:20pm
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
search/ask for the heated engine breather pipe
Standard on scandinavian puma's but not for the rest of europe. These low temps freeze the pipe shut and you get overpressure with possibly this leak as result.
see lasts posts in link: http://www.devon4x4.com/index.php?option=c...;Itemid=81
BTW, great pictures and trip in the link
2cents
Smile [/url]
Post #122082 7th Feb 2012 2:57pm
Specifically this:
Puma Engine Breather Pipe Freezing
Models: Defender (LD)
2.4 Diesel Puma Only VIN-range: 7A732615 Onwards
Markets: Russia and Scandinavian Markets Only
Section: 303-00
Summary: Engine oil leaks.
Cause: Driving the vehicle at temperatures on or below Zero deg C, freezing of the engine crankcase breather hoses resulting in engine oil leaks. Suggested Customer Concern Code - D50.
Action: Should a customer express concern, install a new heated breather kit. Follow the Service Instruction outlined below.
Post #122135 7th Feb 2012 7:15pm
T1G UP
they've had those issues on the trip to the Northern lights on devon 4x4
Post #122136 7th Feb 2012 7:17pm
