Home > Puma (Tdci) > New Defender not starting
Page 2 of 2 <12
Forest of Dean 90
United Kingdom 2007 Defender 90 Puma 2.4 HT Stornoway Grey
""clunking noise and vibrations when slowing down/stopping, loud clutch""
Ask for a new clutch it sounds like the compression springs.
Post #12065 16th Jun 2009 8:42pm
Vger
Slovenia 2008 Defender 90 Puma 2.4 SW Java Black
hadenough wrote:
Sorry to say we have a 110 county and it does it all the time we have to lock and unlock with the key fob and then it usual starts .
Hope this help
Thank you. Unfortuntatelly it doesn't work in my case. I can lock and unlock it numerous times or leave it locked for couple of days but it wouldn't start util I'd pull 30 Amp fuse or disconnect the battery. Confused
Post #12069 17th Jun 2009 12:52am
Vger
I told them about the clutch like 10 times but they are reluctant and wish to replace the transfer case first... Whistle
Post #12070 17th Jun 2009 12:57am
Eduardo
Humm,
Strange indeed. If you have doubts about the cause, IMHO I would start with the cheaper part and if that fails to solve the issue I will change the expensive one. I suposse that the clutch is cheaper than the transfer case. How the dealer would explain to LR service this?
Cheers Eduardo
Post #12071 17th Jun 2009 1:47am
Vger
Eduardo wrote:
Humm,
No, I think they should replace both. Gear whine is most likely caused by the transfer case, but not the clutch noise. We'll see... Neutral
Post #12072 17th Jun 2009 2:00am
Page 2 of 2 <12
