![]() | Home > Maintenance & Modifications > Removable Front tow Hitch! |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Sensible price too
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1196 ![]() ![]() |
Mine is home made, fits both sides and locks into the jacking holes seconds to fit. If everything is under control you are not going fast enough.
Every Day MY 20 Discovery 5 Commercial Workshop and Escort Vehicle Weekends MY 12 L322 4.4 TDV8 Vogue Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
110ross Member Since: 30 Oct 2010 Location: South West Posts: 33 ![]() ![]() ![]() |
Same as the Simmonites one but cheaper.
(same picture too!) |
I think i've also seen ones that fit into the steering guard .. or was that removable front winches ?
Steering guard. Lorryman has one
Nice idea for moving big trailers about - I assume it slips over each side of the dumb iron but I'm not sure a standard bumper (not the galv one shown) would be strong enough. John
http://www.hampshire4x4response.co.uk 2011 Tdci 110 CSW XS |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
I had a removable front tow bar (custom made) on my previoius Disco. At first I diligently used to take it off and stow it after each use. After a couple of months it stayed on permanently for the next four years. With the Defender I again looked at all the options including having a custom heavy duty front bumper made but in the end I bought a couple of 5 inch drop plates, cut one in half to use as a backing plate and bolted it onto the standard bumper as a permanent fixing. I welded a bracing bar to the side which bolts to the chassis using an existing hole where you put the jate ring.
Apologies for the cr**py pic - will aim to take a better one tomorrow. ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2112 ![]() ![]() ![]() |
Good idea
![]() MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
I have the Safari Equip steering guard with the 2" receiver that allows the fitting of a drop plate with towball, recovery billet or a winch mount. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge It only gets fitted when needed, though I still haven't found a need for it being fitted yet. Brian. |
better pic of my (non-removable) one
Lorryman - like the idea of yours - when you do have a need they are worth their weight in gold. It's much easier to control a long trailer/caravan with it on the front rather than the back. One consideration is whether to go for centre mounted or to one side - I've always found it useful being able to see down one side. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Proper job ![]() |
I think it looks good but can't help thinking it a bit of vlad the impailler when off road! Russell 2011MY 110 XS USW Black |
