![]() | Home > Maintenance & Modifications > ACF-50 and Scottoiler FS 365 |
MartinK Member Since: 02 Mar 2011 Location: Clackmannanshire Posts: 2681 ![]() ![]() ![]() |
I've used 2 aerosols of ACF-50 so far (not just on the Defender, but found it to be a really good general lube & protection spray).
ACF seems to be a superb product. MrsK is getting her Evoque on 2nd March, and I was going to buy another couple of cans (well actually I was going to try it in liquid form and use a hand spray-gun I have). However... Scottoiler FS 365 - http://www.scottoiler.com/uk/Lubes-Cleaner...e.tpl.html FS 365 is much cheaper, and would appear to be a similar product...anyone tried it??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Thanks, Zag - looks like it's ACF for me then!
Didin't realise you were a biker as well. Your new avatar confused me for a mo - no more Defender-in-the-woods-with-a-yellow-thing-on-the-back... ![]() I'll order a "quart" of ACF in liquid form I think and see how that works out. Cheers PS my trusty steed in Durness (NW Scotland): ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Didn't realise it comes in liquid form, where do you get it from? Got to be cheaper than an aerosol a week I get through
![]() Avatar courtesy of LR again ![]() |
Yup...
It comes in a "quart" (32fl oz) http://www.chainspeed.co.uk/products/ACF%2...rmula.html Around £30/litre in liquid About £14 for an aerosol which is only a third of a litre (so about £40/litre in aerosol, and £30/litre liquid) Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Great, thanks for that
Lovely bike
![]() I had a Yamaha XJR 1300 - too big to swing about and too uncomfortable on long journeys especially without a screen ![]() |
Members bike pics here
![]() http://www.defender2.net/forum/topic10738.html |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 ![]() ![]() ![]() |
You can get it on eBay too. Often sold with a pump-action dispenser.
Pete |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
Also came across this at the boat show recently - bought some but haven't tried it in anger yet - not sure if it's made by the same people as ACF50 or just same importer.
http://www.corrosionblock.co.uk/corrblock.htm |
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Is this stuff suitable for applying to areas already showing rust? Ive got some early signs of rust appearing on my body cappings which I want to sort out soon.
Yes - as Zagato says, ACF-50 also kills rust. My findings are that it's a superb product...just a bit pricey...but you pay for quality I guess! Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
Polishes the bodywork up quite nicely too (I'm serious)
![]() But shout it at them in German because life is also terrifying and confusing... |
You're not wrong there. When I sprayed all along both sides up underneath the body cappings, I ended up with rivers of the stuff running down the side of the body work, which eventually polished up nicely! Pete |
the quart bottles are definitely better than the aerosols
I just soak a rag in it and wipe my bike all over apart from the seat, grips, rotors and clocks. Everything else gets done including wheels, spokes, forks, plastic bits, levers, bolts, - everything metallic or plastic really. I do use a spray on the engine as you cant really wipe it easily. Also headers, collector, pipes get the treatment. It manily burns off those (clouds ![]() When it gets dirty you just use a light hosing with cold water, not hot, and dont wipe it. Scottoiler is hopeless. Too much fling. I use Wurth High Performance dry lube, works a treat. |
