Home > Maintenance & Modifications > Thief-proof bonnet hinges?
ZeDefender
I know this has been discussed a lot in the past (cable-locks etc.) but is there anything new out there?
Probably driving around Essex and up to Yorkshire later in the year and I don't want to be "scalped" Evil or Very Mad
Matt Tell someone you love them today because life is short.
Post #119496 29th Jan 2012 1:41pm
rusty66
Germany
Wouldn't the Extec (Naka.. and others, too??) hinges that you use bolts with to secure to the bulkhead hinges be some sort of theft prevention, expecially if you use different screws/nuts than standard with them.
They always annoyed me as when working in the engine bay it was a pain to quickly remove the bonnet completely from the Landy.
Post #119504 29th Jan 2012 2:18pm
K9F
OX4X4 Based in Guernsey have got some 'under development.' I purchased some stainless steel ones off them and have 'held off' fitting them as I intend to drill and tap the vehicle (not bonnet) portion of the hinge and fit a grub screw that will prevent the bonnet from raising enough to lift it out of the hinge. There are several options if you do a search. Zagato sourced a bicycle lock if I remember correctly. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #119507 29th Jan 2012 2:36pm
ZeDefender
Laughing Yes - Zag's bikelock (well - mine actually) is my present method...
Thanks for the info - I'll keep my eyes open too Thumbs Up Tell someone you love them today because life is short.
Post #119525 29th Jan 2012 3:47pm
Dave-H
England 2007 Defender 90 Puma 2.4 HT Tonga Green
Mines similar to a bike lock, but a bit more robust ..
Halfords do a 2 metre steel cable with a loop each end ... got that through the 'flutes' on both sides of bonnet, and padlocked together/onto the front lifting eye Smile
http://www.halfords.com/webapp/wcs/stores/...yId_165637 Guns and Landrovers .... anything else is irrelevant.
Post #119532 29th Jan 2012 4:41pm
westfield106
2008 Defender 90 Puma 2.4 CSW Stornoway Grey
derrick at http://www.lrsoffroad.co.uk/ is advertising some cor4 bonnet hinges that he says stop the bonnet from being stolen !!!
http://www.lrsoffroad.co.uk/content/cor4-bonnet-hinges
nothing to do with me just a happy customer of his Bow down Bow down
Post #119643 29th Jan 2012 9:39pm
Dave-H
£63 Shocked
He's avin a larf ................ Whistle Guns and Landrovers .... anything else is irrelevant.
Post #119644 29th Jan 2012 9:44pm
ZeDefender
How much is a bonnet?
If they work, I'm having the black ones Thumbs Up Tell someone you love them today because life is short.
Post #119657 29th Jan 2012 10:05pm
Dave-H
i'll stick to my cable Rolling Eyes
All someone with cnc needs to do is make an ali block with the base shaped to fit on a standard hinge top, that can be bolted on using the two rear hinge bolts [with longer bolts], and shaped in such a way that they butt up against the bulkhead long before the bonnet is raised high enough to lift off the mounts.
I'd buy them ... as long as they were sensible money Rolling Eyes Guns and Landrovers .... anything else is irrelevant.
Post #119670 29th Jan 2012 10:25pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
I tried to take mine off today to clean and tinker the engin but one of the rubber filler/supports ha over turned so when rotated fully to the position that you would remove the bonnet, it has the rubber preventing it. I tried a screwdriver, my brother and a neighbour holding it while I yanked, wiggled and rotate aggressively but it is stuck fast! No scalped getting my bonnet haha. ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #119671 29th Jan 2012 10:26pm
ZeDefender
"Evolution" - the machines are taking matters into their own hands! Whistle
Thought about it some more - why can't a thief just take a hex key and undo the hinge?
I've asked at LRS but any Ideas? PMs probably better than open-forum Whistle
Cheers,
Matt
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #119700 30th Jan 2012 7:52am
landy andy
2 reasons come to mind
One they won't be expecting it so won't have tools
Use of lock nuts so bolts will just spin not undo
You could always just do the bearing in the hole trick?
It is a theft that I really don't understand, the bonnet is one of the pumas nasty parts, but obviously that is just my opinion due to the amount of thefts. Would think yours would be ok ZeDef, as justice is better sausage side Question
Andy
Post #119704 30th Jan 2012 8:39am
ZeDefender
This, fortunately, is true but Lisa and I are planning to do an Essex (did you guess from the name Laughing ) and Yorkshire trip this Summer. Either that or Serbia/Croatia etc...
The "not expecting" bit is hopefully true Rolling Eyes
Excuse my ignorance but is a lock nut more clever just a nut with a bit of plastic inside it?
And what is the "bearing trick"? PM?
Hope you recovered from the horrors of skiing Laughing
I just can't be arsed to do it any more - pointless - net change in altitude = zero Rolling Eyes
Post #119708 30th Jan 2012 8:48am
landy andy
With a lock nut fitted to the fixing bolts,(either nylock nut, or two flat nuts together) you would need to use torx/Allen key on the top and spanner underneath, so won't just be able to undo from above.
The bearing trick is to force a bearing into the hole of the Allen/torx bolt head, so no tool can be used, as hole is blocked.
I also can't be arsed with skiing, pointless, recovering locals that think they are snow driving gods is much more fun Rolling with laughter Rolling with laughter Rolling with laughter
Andy
Post #119710 30th Jan 2012 8:57am
ZeDefender
Think I'm as unclear as ever - the hinge seems to have a hex bolt horizontally through the joint - see the black one here:
Just can't see why it's hard to undo Question
Yes, even with decent winter tyres, people here can get stuck if they try hard enough Laughing Tell someone you love them today because life is short.
Post #119711 30th Jan 2012 9:03am
