Home > Puma (Tdci) > What to get done? Warranty ending
stevie
Got an 09 plate 90 sw with 20k on the clock that is coming up 3 years old. It's booked in for an mot at land rover next week. Anything they find should be under warranty but what should I ask to be checked or replaced?
List I've come up with so far:
Both mirrors have corrosion starting on the arms
Rear window catches starting to show corrosion
Rear window heater elements not working on the top 3 lines
Driver seat foam collapsed on back rest
I ve asked for the above to be replaced but what else should I be asking for?
Post #119076 27th Jan 2012 8:49pm
pom
tell them the washer fluid is ok but everything else is suspect!
Pom
Post #119077 27th Jan 2012 8:50pm
stevie
Laughing
Post #119092 27th Jan 2012 9:17pm
ngarigo
Ireland 2011 Defender 90 Puma 2.4 SW Santorini Black
Pom
Rolling with laughter Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
'Wow...! What a ride!
MY11 90
Post #119170 28th Jan 2012 2:07am
JSG
Pom
But check that first - just in case. Mine was low the other day Thumbs Up John
2011 Tdci 110 CSW XS
Post #119204 28th Jan 2012 10:36am
Zagato
Have a really good look around it yourself, check for any bulkhead, capping's, window frame etc rot and any leaks from underneath, swivels, diff, etc. Spend a morning checking everything yourself first Wink
Post #119206 28th Jan 2012 10:44am
ginjez
2011 Defender 90 Puma 2.4 ST Santorini Black
Have you considered buying an extended warranty. Well worth the money in my opinion especially on our disco 3
Post #119230 28th Jan 2012 12:41pm
K9F
At £70 per month you're having a laugh! Rolling with laughter
A few choice quotes from below threads:-
"Even the dealer-service manager- told me not to bother."
"The dealers WILL attempt to lie and cheat their way out of paying up on an extended warranty."
"Yup, I was offered the chance to extend the warranty on both my Disco2 and Defender (seperately) and the cost was absurd - I would have had to have a major breakdown each year to make it worthwhile."
See here:
http://www.defender2.net/forum/topic7586.html?highlight=extended
http://www.defender2.net/forum/topic10345....d+warranty If you go through life with your head in the sand....all people will see is an ar5e!!
Post #119249 28th Jan 2012 2:08pm
> I'm not sure what they are called, but the door-stoppy things (I had 3 replaced from new)
> check heated front (if fitted) and rear wind screens.
> central locking is working ok (solenoids can fail)
> check alarm / immobiliser
> uppy/downy headlight motors still work
> check underseats for dampness and any signs of corrosion
> fog/reversing lights
> rear wash/ wipe working ok
and finally
> front wipers make sure they are not too clonky
Post #119255 28th Jan 2012 2:32pm
Merlin
Look at the service bullitens in Topix and see if you want any of them done. Like the heater blowing to hot on the passenger, I wish I had known about that one before the warrenty expired. Check the rear step for rust to.
Merlin
Post #119274 28th Jan 2012 3:44pm
Merlin
AFAIK the heater temperature imbalance was LHD only. I've not had it fixed on my MY2010/LHD - would you want a mechanic working against the clock ripping you dash out .. wires, switches and all ? (not me)
Post #119322 28th Jan 2012 6:29pm
MartinK
If I were you - I would not take the car to LR for the MOT, but take it to an independant. I use Dalziels in Edinburgh. They will let me chat to the mechanic whilst the test is ongoing (used the same company for all our family vehicles for several years, so I know all the staff). I would ask the mechanic to be very thorough, and maybe even watch yourself. You'll see a lot more when it's up on the ramps.
My XC70 is 3 years old in April, and I'll be getting the MOT done about 3 weeks before the warranty expires, and asking the mechanic to be thorough. I suspect a worn rear passenger side suspenstion bush somewhere (it clunks ever so slightly) so we'll be having a good thorough look there.
Any MOT fails or (more likely) "Advisories" and you have your shopping-list for the last main stealer service Thumbs Up Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #119375 28th Jan 2012 8:40pm
stevie
The dealer is doing the MOT as they want to find any faults so that they can do the warranty work. So I would think it's in there favour to find any issues so as to be able to do the work. Whatever I can tell them to do will be on top of any problems they find.
That said I've had a good look round today and can't see any obvious signs of any issues. Can only wait and see what the mot flags up.
Post #119403 28th Jan 2012 11:00pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Sorry bpman, but I must have a good dealership as they dismantled my dashboard to replace all the windscreen wipers running gear - saw it in pieces - but everything was replaced as it should be, no squeaks etc:, everything replaced in the dash cubby holes and the radio was working and programmed on FM1. They apologised that they couldn't re-programme some of the stations on FM2 as they couldn't find the stations, not surprising as they were local stations that couldn't be picked up in Cardiff. I guess they vary a lot but mines seems to be OK. They have even reduced the price of the B service so that they are more competitive with the local independents. LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #119422 29th Jan 2012 12:58am
No need to apoligise, that's great service, I had decided not to bother because I did not want to waste time going to/from the dealers half a dozen times getting it all fixed, got me thinking because the way the temperature is distributed, MrsBPman gets the colder air Sad - care to share the dealers details ?
cheers
bp
Post #119435 29th Jan 2012 9:22am
