![]() | Home > Technical > Squeaking clutch pedal |
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Every time I press the clutch in it squeaks any ideas and I have done a search already
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
Mine was doing it, brought it back to the dealer to oil at spring
Squeak gone |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 ![]() ![]() |
I had this happen after 50 000km - LR dealer would lubricate it, it would fix it for several months but come back. Eventually they replaced the entire pedal assembly....that was the only fix that lasted....
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
What?
Proposterous replies! You'll be getting rid of wet carpets and rattles next ![]() ![]() |
Mine has it's own cure..............every so often the master cylinder leaks, first shown by a drip of fluid on the top of your boot and then a fluid mark on the mat. If the mark is added to over 2 days then I need to top up the reservoir otherwis it just dries up and you leave it, very much"If it 'aint broke then don't fix it". My 90 used to drive me mad with its squeak and had to be manually lubed every month
Tried that it's no different. |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
My current Puma pedal has suffered from a squeaky pedal every now and again especially before the spring decided to ping off the pedal some months ago. There is a plastic sleeve in the pedal in which the spring sits, the last time it started to squeak I just put a drop of thick oil on it and it's been fine ever since but it is one of the things on my warranty list the next time it goes in for a service Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
18stone Member Since: 16 Dec 2010 Location: Mid Essex Posts: 137 ![]() ![]() ![]() |
Had exactly the same problem. Whatever I lubricated it with it would still squeak. At the 12k service they said they couldn't get it to do it. Once I'd told them 'rubbish, it does it EVERY time', they went away and fixed it. They just lubricated it but I've no idea what with. That was 1000+ miles ago and it's fine still. D300 HSE 110
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
I bet they used lithium spray grease. That stuff gets everywhere and stays there. All dealers use it to shut people up and make them go away (a Mitsubishi main dealer mechanic told me that !)
Mr Kington Member Since: 24 Dec 2024 Location: United kingdom Posts: 16 ![]() ![]() |
My clutch has been making the noise, very frustrating. Took the plate off inside the engine bay and sprayed it all with lithium. squeak went for about 50 miles and back again. anythign else i can try to lubricate it with ? assume the heat of the engine just dried out the lithium spray perhaps ?
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20998 ![]() ![]() |
As well, as the spring, check if you’ve got a thread in the pedal box, you might be able to fit a grease nipple.
Then you can grease the pivot with ease, only need one pump though on the odd occasion, nothing too much. The nipple size is the same as the Prop UJ’s. Mine had a thread in the pedal box.. Don’t out too much grease in though or you’ll end up with a glob in the footwell or on shoes / boots. You can as mentioned open the lid and grease by hand as well. Lithium grease spray is a bit thin, you really need some lithium grease applied by hand, you can use a touch of like oil like 3 in 1 too to liquify the grease a bit as well. ____\We|Will|Win/___ ____/🇬🇧🇺🇸\____ _//*⛽️🛢️⚙️🧰*\\_ |
Thanks. It’s in for a service soon so may ask them to fit a grease nipple for me. I have k48 moly grease so do you think this will be better ? And thanks
