![]() | Home > Puma (Tdci) > SSM40308 - Just to be aware |
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2111 ![]() ![]() ![]() |
Just appeared in the GTR:
Models LD - Defender Title Mulitiple Starter Motor Failure Last Modified 21-JAN-2009 17:43 Category Electrical Symptom 203000 Basic Electrical Content Issue: Repeat failures on Defender starter motors. Cause: The ignition switch can jam causing starter motor failure due to over running. Action: If the starter motor has failed check operation of ignition switch; a) Is the switch jammed through any of its positions? b) Does the switch fully return to position 2 once cranked and the inhibit operates, not allowing re-crank from position 2? c) Does the starter motor continue to engage once cranked and key released? If the answer to any of the above is YES please change ignition barrel as well as starter motor as potentially the starter motor will fail again. Vehicles post vin. 775971 have been modified and should not demonstate this concern. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
funny that - not quite the same but on 2 occassions I've been unable to move the ignition to stage 1 from 0 (if thats the correct positions - ie from off to 1st position) - and no its not because of the steering lock.
The first time it happened I was just about to abanded the vehicle and then it worked ![]() No issues with the starter though. |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 ![]() ![]() |
My TD5 had a steering lock, and it caught me out a time or two. Wasn't the easiest to disengage.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5112 ![]() ![]() ![]() |
Ive got to check for this now, ive not ever come across one and always thought it was odd...i assume its no more turns than any other car>? Mike |
dullbird Member Since: 25 Aug 2007 Location: sydney Posts: 87 ![]() ![]() ![]() |
mine goes on really easy on the disco just got to bump the steering wheel, not so sensitive on the defender.
MSE: before you put the key in give your steering wheel a wobble and you will hear a short click then you wont be able to move it at all.....you then put the key in the ignition and you might find you have to give the steering wheel a jiggle as your turning the key to get the lock off YOU KNOW REHAB IS FOR QUITTERS!!!! |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
It locks i found out - but with amazing movement to get it to do it! Mike
