Home > Puma (Tdci) > Some other wires needing protection
CapeLandy
South Africa
Found a couple other wires/break pipes and cables needing protection from chaffing. Stuck some left over sprague tubing to reduce possible damage.
 Puma 110 - gone
Series III 1973 - going strong
Post #11818 10th Jun 2009 8:22pm
mse
im not seeing any of those wires immediately where you say that arent protected - its raining so i cant go out an check over the photos i have on mine Mike
Post #11828 10th Jun 2009 10:18pm
CapeLandy
South Africa
I suppose I should have explained better.
The group of wires running past the vacuum break cyliner on the outboard side were chaffing on the lip of the booster. These wires are merely taped together with insulation tape.
The next is some sort of cable (maybe the bonnet release) which runs past the inboard side of the vacuum break cylinder and then straight next to the heat shield - mine rubbing against both above items.
The other is the now "bent away" break pipe only mm away from the heat shield now rubs against the other break line below the heat shield. I put some sprague tubing with a cable tie over that section of break line also.
Hope this helps some of you
Regards
James Puma 110 - gone
Post #11835 11th Jun 2009 6:29am
Grockle
Thanks CL, will have a look Thumbs Up 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #11870 12th Jun 2009 10:33am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
I've already been over that area and put some conduit over wires and hoses in that section. I'm spending this weekend crawling over the Puma in preparation for a big trip in 12 days time. If I find anything significant, I'll post it up here too. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #11871 12th Jun 2009 10:39am
CapeLandy
South Africa
Upcomming Trip
D.M - 12 days for you 14 sleeps for me until Botswana - can't wait. First big trip we are doing. Hope my new radiator hose arrives by then Mr. Green
Goood luck with the crawling about the fender on the weekend. I have to spend mine at work assembling a troublesome propeller shaft that was a can of worms when we opened it up.
 Puma 110 - gone
Post #11875 12th Jun 2009 11:18am
CapeLandy
South Africa
nearly done
Almost there now Very Happy
 Puma 110 - gone
Post #12033 16th Jun 2009 9:41am
