Home > Maintenance & Modifications > In Car wiring How to?
RRUK
In a few weeks time I shall be replacing my front section headlining for a full length La Salle version, and I shall be adding in stereo, speakers, additional lights inside etc.
I've not done any automotive electrics for some time, can anyone give me any golden rules or best practice tips, how to articles etc?
What sort of kit does a DIYer like me need? I still have my old crimp tool, but should I be learning how to do soldered joints etc instead.
If I were to add a set of spotlights for example, I have no real clue whats involved and how to wire them up, but I learn quick.
Thanks chaps 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #118294 25th Jan 2012 9:00am
This may be of some use to you for spots at least
Just make sure that anything that is permanent live (direct from battery) is fused. For example two 100w spots would require 1 x 30amp relay and be fused with a 20amp blade fuse as the power consumption they would use would be roughly 16amps.
For everything else que K9F Rolling with laughter
Post #118320 25th Jan 2012 11:34am
Mark_110DCPU
United Kingdom 2001 Defender 110 Td5 DCPU Chawton White
Here is a good how to for crimps - I would read this before resorting to soldering stuff:
strong and reliable crimp joints
It is also worth buying the correct thinwall, multistrand wire in sufficient different colours to allow you to differentiate circuits correctly - there is nothing worse than coming back to it later when it is all in red and black, or worse all one colour!
The likes of VWP or Polevolt are good suppliers...
hth
Mark [:O|===|O:] 2001 110 TD5 Doublecab
Post #118376 25th Jan 2012 2:39pm
Martin
Site Admin
Draw a diagram and keep it safe so you can work out what you've done at a later date.
Also highly recommend thinwall cable of the correct rating, and using lots of colours to separate different functions.
eBay is good for selection packs of cable, connectors, tools etc if you don't want loads.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #118395 25th Jan 2012 3:59pm
Try http://www.vehicle-wiring-products.eu/VWP-...mepage.php
for all your wiring needs, we use them a lot for our Ibex builds... QRZ 2e0vpf
Post #118396 25th Jan 2012 4:14pm
