![]() | Home > Puma (Tdci) > 2nd Service (24K) pricing? |
Use an independent for main service,
i used one excellant job and it only cost me £220+vat maindealer £530 big differance http://www.deeside4x4.co.uk/ NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
Less at Guy Salmon Stratford, £449.
Droitwich were quoting £510. I'll probably use my previous independent once out of warranty, I know they will be cheaper. |
YORKSHIRELAD Member Since: 17 Mar 2009 Location: West Yorkshire Posts: 159 ![]() ![]() |
I think you can still use your independent without effecting you warranty?
Richard 1963 Series 2A truck cab 2008 110 SW |
Yess your right and still covered for warantee work ![]() |
Yeah, I appreciate that you're right guys... but as I'm having warranty issues looked at, at the same time... just saves me from doing two separate trips (20 to 30 miles to nearest dealers & independent for me).
If there were no niggles next service time, I'll happily go independent. |
No issue in using independent dealers as long as they use gen parts and are VAT registered. 2.4 90 XS
markalpha Member Since: 23 Apr 2008 Location: Downham Market Posts: 690 ![]() ![]() ![]() |
If you have a Dealer do the servicing LR have no chance not too honour warranty issues and the dealer will be more on yourside when dealing with problems. With an independant doing the work, it may just give LR a get out clause. I know that leagally this is not the case but could end up giving you a headache!.
Forest of Dean 90 Member Since: 29 Apr 2009 Location: Forest of Dean Posts: 68 ![]() ![]() ![]() |
J V Like (main agent Brecon) did mine for £320 as well as Warranty work
My Dealer has no issues with me using an independent, as long as thay use genuine parts had mine serviced by independent thay picked up on 2 swivelseals leaking took back to dealer next day sorted but if you guys have hundreds of pounds spare go head and keep your dealer happy ![]() |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5108 ![]() ![]() ![]() |
Ring around - i played the dealers and haggled saving £120 on the first service Mike
