Home > Technical > Whining Noise! |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 |
box comes out from underneath without touching the engine
6th Jan 2012 2:01pm |
Confirm! Fromunderneath removing the central crossmember, not difficult Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
6th Jan 2012 2:06pm |
Scallops Member Since: 15 Aug 2007 Location: Brisbane Australia Posts: 89 |
My noise extensively checked by trusted LR specialist, diagnosis normal transfer case hum....
23rd Jan 2012 8:43am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2603 |
'normal' until it breaks. and that usually happens when the warranty has expired. effing LR... -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
23rd Jan 2012 8:47am |
They took the tc out and had a good look, whilst they replaced my rear main....these guys are not LR, they are very well regarded specialists here in Brisbane (MR automotive)....they say it's normal....I believe them. If it were LR saying it, I probably would be sceptical! If it does break after warranty, I'll fix it myself....what do they say about anything with an engine or breasts?.... The reason I hadn't heard it before was that I used to run mud tyres. |
23rd Jan 2012 10:30pm |
