Home > Td5 > Speedo not working either!
Arbman Al
As well as the wipers not behaving, took the lan dy out for its maiden drive after completing the conversion from 300tdi to TD5 and manual to auto only to find that the speedo doesn't work.
Fitted a new oem transducer (black), and plugged into the TD5 loom but no worky?
Could this be linked to the wipers not working? 1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #117668 22nd Jan 2012 11:06pm
Do you get the mileage figure on the speedo? (question is really aimed at is there power getting to the speedo)
Or is it the transducer not giving as signal to the speedo head.
Post #117699 23rd Jan 2012 8:34am
Arbman Al
I've got power ok.
Apparently I've got wrong transducer - should be a green one. 1996 Defender 130 converted to TD5 and auto
Post #117775 23rd Jan 2012 3:57pm
landyman37
I've got power ok.
Hi done this same converstion had the same problem has your transducer got 2 or 3 pins in it mine had two so had to change it for a td5 one. The plug also only had 2 pins in had to add another one for the earth.
Phil
Post #119398 28th Jan 2012 10:44pm
Arbman Al
landyman37 wrote:
I've got power ok.
Phil
Keith Gott refunded me for the black transducer and supplied the green one, both had a three pin plug.
Speedo now works as it should. Thumbs Up 1996 Defender 130 converted to TD5 and auto
Post #119703 30th Jan 2012 8:05am
