Home > Technical > where to start......
Caterham
firstly not sure if this is the right place for this but....
as I'm sure some of you will have seen the really smart converted sankey trailer in the photo album (I think it was sonic3d).
anyway I'm thinking about creating something similar but I'm wondering what guage ally sheet I should use?
(I bet you're all thinking if I don't know what to use perhaps I shouldn't even attempt to make one?......well thats what I'm thinking anyway?)
any other advice would be very much appreciated Thumbs Up
Post #117618 22nd Jan 2012 9:00pm
T1G UP
well it depends on the framework i guess. I've seen marine ply sides with a thin guage ali sheet glued to that. 2mm thick?
Ali is soft and marks easy. What about zintek or galvy sheet steel. Won't rust and won't dent as easy.
If you going box section frame then thicker guage or even signage board which is laminated and you can by upto 8mm thick.
Or use durbar, check plate to the masses. Think it looks Censored but thats my view! Ali can be rivetted obviously or welded which can be costly...especially if i'm doing it Whistle
some late night reading! http://www.expeditionportal.com/forum/thre...ler-Builds
Post #117622 22nd Jan 2012 9:04pm
Caterham
T1GUP.
great link.....and I'm sure there will be more questions coming your way.
thank you .
Post #117718 23rd Jan 2012 10:15am
T1G UP
i've just bought a trailer so this is on my mind alot TBH! off in june,wouldn't mind it done for then
Post #117843 23rd Jan 2012 7:15pm
Zagato
3mm is probably strong enough but as it's quite thick it can crack if you bend it Sad You would probably be building a frame for the panels anyway so 2mm as TIG says and attach it Thumbs Up
Post #117847 23rd Jan 2012 7:20pm
T1G UP
so whats your plans, teardrop style sleep IN or storage cooking etc and a RTT?
Post #117850 23rd Jan 2012 7:26pm
Caterham
the plan is to replace the standard tub off the sankey 3/4 ton and having someing this simlar to that in Sonic3d's album.
so rear door but probably a slide out which might be able to double up as a table, probably internal space for gas bottle(s), hinged lid to access general storage space for tent, beds etc and facility for roof rack which would likely be used for carrying bikes......and most importantly in stornaway grey !! Very Happy
Post #117913 23rd Jan 2012 9:13pm
Caterham
in terms of construction my thoughts were ally / ply base with tub made from flat ally with riveted angles in the corners and riveted bracing from 'u' section ally. internally clad with sticky back sound proofing or similar to minise dents (from the inside out at least and to protect contents against direct contact with metal work.???
Post #117915 23rd Jan 2012 9:18pm
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
I'll have a look to see if I can find the thread on Disco3, was a cracking build on there a while back Thumbs Up
Edit: found it : http://www.disco3.co.uk/forum/topic47201.html Wiggs is a top guy, bought my spotlights off him a while back, I'm sure he'd help with any questions.. thread is well worth a read though Thumbs Up
Alex 110 Tdci Double Cab
Post #117942 23rd Jan 2012 10:26pm
Caterham
fantastic links - thank you very much.
Thumbs Up
Post #120830 3rd Feb 2012 10:59am
