![]() | Home > Technical > Thrash or not to thrash? |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
um........what is exhaust braking
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
Jake brake explained &feature=related And a exhaust brake &feature=endscreen&NR=1 get one for the defender?! |
Thanks TIG, i had no idea they existed, what a great use of engine power/torque to slow you down.
cheers BM52 |
thats the low deep rumble you here from lorrys when going down hill
Exhaust brake and full gas leaves a full smoke trail behind
RED-DOT Member Since: 29 Jun 2009 Location: stirling Posts: 2363 ![]() ![]() |
Exhaust brakes cause huge upper cylinder pressures and the heat generated absolutely cooks the exhaust valve stems which melt the rubber O ring seals which soon causes oil to run past and burn on acceleration and more so on decelleration. Modern engines cut the fuel off as soon as the EB is applied. Clever hauliers disconnect due to this and they know the drivers can use in situations where the footbrake should be utilised. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Sorry not a clever idea
Exhaust brakes are invaluable on long descents they save the main brakes for when you need them . Seen many a rig pulled over with cooked brakes. |
chiefstoker Member Since: 11 Oct 2010 Location: Weston-super-Mud Posts: 897 ![]() ![]() ![]() |
Amazing haircut on the dude ![]() Beer 'n Sex 'n Chips 'n Gravy ![]() |
Today i did about 100 miles mainly on B roads cross country through Kent/Sussex and i don't think i went above 3k at any time, cruised mainly around 1600 - 2000 without effort or any strain.
one short M23 part but that was less than 2.5k and maybe up to 3k as i went through the gears to get up to speed. torque not revs seems to be the way ![]() |
