![]() | Home > Puma (Tdci) > I have a rattle! **SOLVED** |
cinstone Member Since: 29 Nov 2010 Location: Stourbridge Posts: 375 ![]() ![]() ![]() |
Err, miles, err....about 35k or so.
Yes there's been problems, all compounded by the stealer. Still got the rattling gear stick under load, but, touch wood (my head) nowt serious as yet. On our trip to the Isle of Man my girlfriend said that "Michael had never let us down", well apart from the EGR playing up last year, which didn't cause any problems as such and the Derby dealer sorted under warranty before we left for hol's, which was great cuz' it got me out of most of a meeting ![]() Still, he did me proud on the off road course at Billing, where I drove both green and red routes, except for the deeper water crossing at the side of the lake and the mud bath. All on General Grabber TR's. Chris. http://shropshirelandrovers.freeforums.org 2015 Defender 90 XS SW & Helen, 1964 IIa. Previously 2012 Defender 90 XS SW & 2008 90 XS SW. Previous LR's: Michael, my 2008 Defender 90 XS SW. Machinas oportet intrare non capsicum annuum faveo |
lrMike Member Since: 26 Feb 2010 Location: Athens Posts: 177 ![]() ![]() |
What tape or other material would you recommend to put around some hoses and cables into the engine bay to eliminate all the rattling while there is contact between them and other parts of the engine bay?
Just wondering... Mike. |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17859 ![]() ![]() ![]() |
I can't see any reason why thes seats need to be bolted back anyway. One of the first mods I made to my DC was to remove these brackets so I can tip the seats, and now I have easy access to a huge, otherwise wasted, storage area. The seats latch properly into place without the brackets and are just as secure as the SW or UW seats. I have an untraced rattle on mine though, which has defeated all efforts to track it down. It sounds for all the world as though the fitting at the upper mounting of the driver's seat belt is rattling - a fairly substantial metallic rattle that seems to be coming from the vicinity of my right ear. However there's nothing loose on or around the B post, and I have even had the headlining out to see if a spanner has been left in the cant rail! Can't find the source though! |
puma110 Member Since: 28 Feb 2011 Location: Australia Posts: 7 ![]() ![]() |
[quote="blackwolf"]
I have an untraced rattle on mine though, which has defeated all efforts to track it down. It sounds for all the world as though the fitting at the upper mounting of the driver's seat belt is rattling - a fairly substantial metallic rattle that seems to be coming from the vicinity of my right ear. However there's nothing loose on or around the B post, and I have even had the headlining out to see if a spanner has been left in the cant rail! Can't find the source though![/quote] Hi Blackwolf, If it's the same rattle as mine, and it sounds like it may be, mine actually comes from the drivers door latch. The latch that is fixed to the pillar where the door latches onto has a small plastic tube on it that is now slightly scratched and loose on mine. This causes a rattle when i drive. The way i temporarilly fix mine at the moment is just open the door, spin the little plastic tube around 180degrees and close the door and all is good. Not a real permanent fix but it does the job for the time being. Cheers, Chris |
llessur Member Since: 15 Nov 2011 Location: Hereford Posts: 151 ![]() ![]() |
I would just like to confirm the above.
For weeks I had a rattle at ear height - presumed from B pillar but could not find a thing. I even wedged matchsticks in the rear glass in case it was that rattling. By accident I openned the door, closed it and it disappeared. So now, I just open the door and slam it and the rattle stops. Seems crazy though as the door latch is at waist height and the noise sounds like its at ear height. I can put up with most rattles - even the wife |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Just a thought as sound travels, have you checked the window regulator bolts are tight? ![]() Click image to enlarge Brian. |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
Are those the bolts that cause the window to fall out if they are lose?
Yes they are Zag. I had a rattle in the pillar and it turned out this was the cause of it, as it did not reoccur after I loctited them.
Brian. |
Loctite 243, medium strength threadlock.
If they rattle at least it should give you some warning before the windows fall out - hopefully
Milesg Member Since: 13 Feb 2017 Location: Macclesfield Posts: 1 ![]() ![]() |
I had a rattle that sounded like it was coming from door frame of passenger front side. Turned out to be all the repair equipment stored under the seat in the battery compartment. Cushioned it all and taped down including the clip holding the cover over space. Sorted it!
Nitroneil Member Since: 05 Mar 2019 Location: Stirling Posts: 132 ![]() ![]() |
Post reserection, totally gobsmacked. On dcpu i had a fair amount of squeeking and just general noise from door pillar area, rear doors. I removed side step runners and fitted a pair of fold down steps to froont doors, went to work today and all quiet! It seems the added support of step bar running in to chassis each side has helped stiffen things up. Also i thought I had a rattle behind dash at passenger side, turned out it was clip missing on wheel spat.
