Home > Technical > metal chips on my tranny...
Page 2 of 2 <12
ZeDefender
bm52 wrote:
do you have to take the driver seat box cover off to get to the gearbox filler hole?
Not on the Puma (MT82) - all you need is the right size hex key, a flexible pipe and the means to pump in 2.2 litres of golden happiness.
Oh yes - and yoga classes before and after Laughing
p.s. do you want detailed instructions (can also be found in other posts)? Tell someone you love them today because life is short.
Post #116338 17th Jan 2012 10:58pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
thanks, thats good news. got a few hex sockets thanks and i assume you dump all oil and pump in exactly 2.2 litres?
oh - my wife does yoga so this looks like a job for her Twisted Evil BM52
Post #116347 17th Jan 2012 11:11pm
ZeDefender
Bear in mind the drain and fill plugs are "sockets" themselves, so I just bought a hex key and cut it to size. The plugs are easily identifiable as they are black but the filler is awkward as hell to get to (you'll find out Laughing )
In any case this one is the drain:
and this one the fill:
Procedure:
Warm up gearbox oil a little by going for a short drive (e.g. 10 minutes).
Use 8 mm hex/inbus key to remove the fill plug FIRST and the drain plug SECOND. When replacing oil plugs, clean and tighten to about 35 Nm.
Volumes:
First fill at factory is reputedly 2.4 litres (2.6 litres on Mustangs)
Refill should be 2.2 litres (to account for residuals), althought anything between 2.2 and 2.4 is fine.
God, how I love to talk :wink:
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #116352 17th Jan 2012 11:18pm
bm52
thank you, post copied into my Puma Service folder - thinking i'm becoming a laptop OCD freak ! BM52
Post #116356 17th Jan 2012 11:23pm
rossy
after a lot of messing around with pipes and funnels I found the easiest way was to fill the box from underneath the car.
If you are using normal 1litre containers with extendable flexible spouts then you can coax the spout into the filler hole (by bending it with your index finger) with the container upright. Then keeping the spout in the hole swivel the container to the upside down position. There is just enough clearance between the gearbox and the transmission tunnel to allow you to do this if you do 1/2 a litre at a time.(don't start with a full bottle or it will go everywhere).To get 2.2 litres in you need to do this about 5 times !
There are more professional ways of doing this job of course but thats what worked for me Thumbs Up
Post #116360 17th Jan 2012 11:24pm
ZeDefender
Thumbs Up Tell someone you love them today because life is short.
Post #116361 17th Jan 2012 11:26pm
totoD110
Thanks guys for all those reaasuring words... Wink
1 More question as per manual the oil to be use is the castrol 130 for the tranny. we only have 90 and 140 available here. i put 140 and it goes fine. is it good to put 90 as long its synthetic?
Post #116451 18th Jan 2012 1:42pm
Page 2 of 2 <12
