![]() | Home > Maintenance & Modifications > Heated mirror from heated screen |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Morning all
It's minus 12 outside this morning and I've changed my mind... I really would like a heated wing mirror! As I have a long large purple wire easily accessible for the heated windscreen, can anyone give a reason why I shouldn't take a spur off it and use it for the mirror too? Using the same heater switch would be perfect. The screen uses a 30A fuse and the mirror I'm looking at is rated 15A max. Guess I could uprate the fuse a bit if neccesary... Otherwise I probably won't bother (lazy Cheers Matt p.s. yes, I've searched (...a bit) Have a terrific day all But shout it at them in German because life is also terrifying and confusing... |
| tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1125
sorry to jump on your tread,is it much of a job to fit a heated screen and mirrors to td5 which has none
thanks |
Great, thanks Do you stick with the 30A fuse? Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328
Yep no issues at all
| blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 18038
A little o/t but related to this question:- I am planning to fit a heated screen (plus probably heated mirrors) and was also thinking of connecting theme to the same switch (I can't use the HRW circuit since I have already used that for something else).
With the standard heated screen wiring, I know that there is a timer to switch the element off after a certain period, but can it also be switched off manually before the timeout, by means of a second switch activation? or is it always on until the timer times out? Thanks. |
| LandRoverAnorak Member Since: 17 Jul 2011 Location: Surrey Posts: 11327
Yes, by pressing the button again. Mind you, the timer is only about 10 minutes, IIRC. Darren
Update - heated mirror is now fitted and works a treat
Gets pretty warm very quickly though - hope it lasts Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
| BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785
Right I fitted a heated wing mirror kit over Christmas but several attempts to get it working have all failed
I did have one working and found I has a loose wire so connected it and just caused the working pad to stop 2011MY 110 XS USW Black |
| WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748
As well as buying the heated mirror elements, am I right in thinking you can also buy heated mirrors as a complete unit?
| dgardel Member Since: 30 Nov 2008 Location: Veneto (Heart & Head) Posts: 3586
Where you routing the cable? photos?? Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License |
I bought a complete mirror unit (not the bracket) and there is a cable (about 3' long) sticking out of it with 2 wires. Just mount the thing on the bracket ball. Whole unit was about 30 quid.
To route the cable, I drilled a hole through to the inside, just above where the door hinge fixes to the frame. There is just enough room here (you can see it's a bit "deeper" on the inside where the door seal bends). I angled the hole slightly upwards to encourage water to come out instead of in. The frame has two skins, so to prevent chafing, I made a sheath out of a bigger piece of rubber cable to pass through the frame (slanting slightly down) and sticking out a bit both sides. Everything was glued in place with polyurethane glue and sealed up with Sikaflex (brilliant stuff As I have a heated front windscreen, the rest was easy. I just soldered the brown wire to the windscreen heater connector and drilled a small hole just above the top "fake hinge" bolt and used a self-tapping screw to fix the blue wire to earth. The mirror just works exactly the same as the windscreen Photos tomorrow if anyone is still awake... p.s. Still trying to convince the wife to go back to Caorle this year But shout it at them in German because life is also terrifying and confusing... |
Thanks, where did you buy the mirrors from? Photos would be useful for me please |
<thank you Ze, please take a photo " I drilled a hole through to the inside, just above where the door hinge fixes to the frame"
| bpman Member Since: 21 May 2008 Location: Oslo Posts: 8069
did you put the mirrors in upside down ? |
