Home > Puma (Tdci) > Headlamp Guards any recommendations.
Page 2 of 3 <123>
T1G UP
Scrapheap challenge more like.
wheres Killer90, he'll put some LEDS on it and Bob's your uncle Thumbs Up
Post #115712 15th Jan 2012 8:41pm
Dean Watson
United Kingdom 2011 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Duralac no good then
Zag
Why do you think duralac and stainless bolts wont stop dissimilar corrosion, thought thats what this stuffs for?
What do you suggest then?
Post #115722 15th Jan 2012 8:59pm
There's a company on Bay selling some substantial looking traditional ones that have been galvanised. CLICKY LINK
Either painted or powder coated, they seem like a good solution to the usual problem of them rusting when the coating flakes off. Darren
Post #115731 15th Jan 2012 9:25pm
Zagato
Re: Duralac no good then
Dean Watson wrote:
Zag
It's a perennial problem of course, well discussed on LR and Boating forums. I wish I had a more retentive memory or paid more attention at the time but there are loads of threads on this and they start of when someone suggests Duralac as it's so well known but then others come in with better products (sorry don't know the name of!) and good give reasons for them such as Duralac actually holding water! Maybe a search on here and boating forums such as YBW.com.
Half the problem is not letting the metal come into contact with each other, any substance will just get squashed out, self tappers for instance rely on gripping the metal so the equivalent of raw plugs have been suggested, easier in your case if you are using bolts. Maybe put the bolt in a sheath and paint the edges of the exposed ali where you have just drilled (may need etch primer for some paints!) plastic washers maybe and plaster the whole lot in something whilst fixing Thumbs Up What ever you do it will corrode eventually (long time) it's just staving it off!
Sorry cannot be more help but searching should help to identify the good stuff...
Post #115749 15th Jan 2012 9:55pm
Odin
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
My Defender came with the standard LR guards fitted front and rear - what a pain in the ass they are. They won't be on future purchases that's for sure. So, do you really need them fitted?
Post #115763 15th Jan 2012 10:11pm
T1G UP
i had them on my td5. TBH for me the front equipe ones will be added security for the headlight upgrade i'm considering! thats all. I don't want the holes in the wings and i can remove and replace the xs light surrounds and grill and no one will ever know
Post #115769 15th Jan 2012 10:27pm
scottish110
Scotland 2007 Defender 110 Puma 2.4 XS CSW Santorini Black
Defo DONT go with the ones that bolt up onto the panel above the lights. I bought my 07 with them already on and when i went to try to change the light bulbs i couldn't get the bloody screws out because they were rusted right through and the thread was stripped ! To say the least i wish they were never on cause now im going to have 4 holes that will either need patched or i'll have to buy new panels, spray them, and fit them which will cost me around £400 to £500 Big Cry
Post #115839 16th Jan 2012 9:28am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
I bought these off a chap who had a couple of sets made a few years ago.
Post #115842 16th Jan 2012 9:39am
You could go for these
No corrosion issues, no alignment issues, no bulb-changing issues, and they should fit! Thumbs Up
Post #115866 16th Jan 2012 11:34am
leeds
What are people trying to achieve with these light guards?
If protection from stones being flicked up and smashing glass then it is a bit hit and miss if those guards work
Land Rover do some poly carb light protectors. They do take some beating from stones before they crack. Downside of these are that if you use stick on beam deflectors then since front of light is warmer the glue will go brown after a reasonable time period
Brendan
Post #115909 16th Jan 2012 3:10pm
SGH
Light guards are for looks more than a practical solution plus a pain to clean the lights.
If you get a knock on a light guard then you are into bodywork damage.
In most cases it's the guard that causes the damage. Laughing 993 Varioram - Guards Red
Defender 2.5 300TDI 110 HCP - Keswick Green
Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE
Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE
Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE
Post #115916 16th Jan 2012 5:18pm
ngarigo
Ireland 2011 Defender 90 Puma 2.4 SW Santorini Black
these are mine... equip style... sort of... solid, heavy... quality... love em Thumbs Up
http://www.ebay.com.au/itm/ws/eBayISAPI.dl...0709533892
31 by Defender 90, on Flickr
29 by Defender 90, on Flickr
30 by Defender 90, on Flickr
27 by Defender 90, on Flickr Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming...
'Wow...! What a ride!
MY11 90
Post #116386 18th Jan 2012 5:09am
Old school:
Post #418565 24th Apr 2015 8:29am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Payustech
http://www.payustech.it/wordpress/product/...iori-nere/
Equipe 4x4
http://www.equipe4x4.com/negozio/griglie/g..._-_coppia/ Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #419017 25th Apr 2015 9:02pm
smb
Completely disagree! Unless I'm the exception to the rule, Cor-4(similar to the Equipe ones) saved my speakers from being smashed to hell by half an engineering brick flying up from the back of a wagon doing 50mph. No damage to wing either. Only the guard was bent in about 5-10mm.
Unfortunately, they won't fit on with an ARB Deluxe Bar and so now they sit gathering dust on a shelf Crying or Very sad
Choosing to put light guards on was primarily function over form. Choosing Cor-4 however was because all things considered they looked the best in both aesthetics and more importantly strength. The finish is not the greatest, but still a lot better than the finish on most after market stuff. Plus, as Derrick at LRS was selling them that was a good enough testament for me. I believe they are now very difficult to get hold of like with all Cor-4 stuff Crying or Very sad
[/img]
[/img]
Post #419030 25th Apr 2015 9:50pm
Page 2 of 3 <123>
