Home > Td5 > Whats this wire for?
Arbman Al
Me again!
Can't find what this connects to. It comes out of the engine loom near the MAF wire:
[/img][/list]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  1996 Defender 130 converted to TD5 and auto
1975 Triumph Stag 3.0 V8
Post #115572 15th Jan 2012 4:07pm
landy andy
Do you wire connected to the air sensor in the air filter housing? Same loom as MAF?
Andy
Post #115573 15th Jan 2012 4:17pm
landy andy
Pm'd
Andy
Post #115575 15th Jan 2012 4:23pm
Martin
Site Admin
Is that going into a split in the air filter housing or just a trick of the photo?
What are the wire colours?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #115579 15th Jan 2012 4:40pm
Martin
Site Admin
It's just jumped out at me that it's a pin terminal. Let me know the wire colour though Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #115581 15th Jan 2012 4:43pm
Porny
Site Sponsor
Inertia switch wiring?
What colour is it?
Ian
Post #115586 15th Jan 2012 5:11pm
Arbman Al
Thanks for the replies so far.
Will check the wire colour tomorrow.
It's not the inertia switch as that is wired in, and the two connectors to the air box are connected as well.
If its a pin terminal I'll have to see if it has pulled out of something.
Should have checked the wire colour when I took the photo - doh! 1996 Defender 130 converted to TD5 and auto
Post #115587 15th Jan 2012 5:17pm
Porny
Site Sponsor
Looking at that pictue again...
Crank sensor wire (if two wires) or oil pressure sensor wire (if single wire)
Ian
Post #115596 15th Jan 2012 5:47pm
Arbman Al
Ian
It's a single wire, and I don't recall plugging anything for oil yet.
Where should it connect to?
Cheers....Al 1996 Defender 130 converted to TD5 and auto
Post #115601 15th Jan 2012 6:12pm
Porny
Site Sponsor
Cheers....Al
If you look under the turbocharger - about halfway down the engine block, you should see the oil sensor. You will need to find the correct plug to replace the missing one (is a 2 pin plug, but only one side is used). Can get a picture if needed.
Ian
Post #115607 15th Jan 2012 6:33pm
Arbman Al
Cheers....Al
Ian
Thanks Ian,
Will have a look tomorrow.
Conversion nearly finished now, just got to sort out the auto shifter position....
Cheers...Al 1996 Defender 130 converted to TD5 and auto
Post #115777 15th Jan 2012 10:41pm
Arbman Al
Mystery solved - it is the oil pressure sensor wire, and found the plug on the sensor, so that was good.
Cheers for the help.
Post #115917 16th Jan 2012 5:26pm
