Home > Technical > transfer box q's
westfield106
2008 Defender 90 Puma 2.4 CSW Stornoway Grey
transfer box q's
hi
are the transfer boxes the same in the tdci as the td5 ie lt230 1.4 ratio ???
cheers
john
Post #114076 10th Jan 2012 5:48pm
landy andy
Think the Tdci uses the 1.2 trans box like the disco
Andy
Post #114082 10th Jan 2012 6:19pm
jst
td5s are 1.4 tdci are 1.2 Cheers
James
110 XS Utility
130 Puma Station wagon/camper (in the making)
90 Puma Hardtop
Post #114086 10th Jan 2012 6:28pm
just to be clear, defender td5's are 1.4, defender 2.4/tdci's are 1.2
(discovery td5's are 1.2)
Post #115218 13th Jan 2012 11:39pm
westfield106
thanks for the replies Thumbs Up
is it possible to fit a transfer box from a 300tdi disco then -- provided its fitted with difflock ??? as they are lt230 1.2 ratio ???
Post #115447 14th Jan 2012 9:35pm
ben_j85jty
United Kingdom 2002 Defender 110 Td5 XS DCPU Bonatti Grey
I put a disco transfer box into mine 2 weeks ago and it had turned out great.
Mine was from a 300tdi, going into a TD5 110.
Few things to note -
Difflock switch is different and needed re wiring
Hi Low switch won't fit
Speedo over reads - I will look into changing the plastic cog to fix that at some point.
Had to remove the harmonic dampner.
All told, it was an easy job taking 3 hours to complete. 2002 Defender 110 DC
Post #115456 14th Jan 2012 10:05pm
T1G UP
why? the tdci has CDL aswell.
Post #115457 14th Jan 2012 10:05pm
westfield106
thought some of the discos didnt have difflock lever etc ??? fitted with cdl but no levers to activate it ??
mine is noisy when you engage cdl even when at crawling pace -high or low box --- ideas welcome but presume fault with cdl so looking at replacing transferbox and wondering which ones are compatible
Post #115459 14th Jan 2012 10:12pm
T1G UP
thought some of the discos didnt have difflock lever etc ??? fitted with cdl but no levers to activate it ???
later td5 discos didn't have CDL.
but why do you want to change yout tdci TB for an older ones???
Post #115460 14th Jan 2012 10:17pm
Martin
Site Admin
According to his icon, the OP has a Td5, not Puma.
We've not been told why the original question was asked, that bit of info is missing, hence the confusion I think!  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #115462 14th Jan 2012 10:19pm
T1G UP
well he says he's just bought a puma!
Post #115464 14th Jan 2012 10:20pm
Martin
Site Admin
OK, but you didn't need to repeat what I just said Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #115465 14th Jan 2012 10:21pm
T1G UP
ok
Post #115469 14th Jan 2012 10:26pm
ben_j85jty
CDL was deleted for some of the disco 2 period, so a 300dti disco box will be fine. 2002 Defender 110 DC
Post #115470 14th Jan 2012 10:30pm
westfield106
icon needs updating as of today Thumbs Up
avatar is of my 200 tdi offroader Smile
bought an 08 tdci with 20k mls on it owner said difflock had never been used !!! but if you select difflock then it makes a loud rumbling noise from transferbox area ??? drives ok without difflock engaged. just driven it 70ish miles home without fault Very Happy Very Happy poss have access to 300tdi transferbox to try before i dive in and order a new transferbox from ashcrofts so just wanting to clarify compatibility ????
Post #115472 14th Jan 2012 10:31pm
