![]() | Home > Off Topic > Memory Map 2012 |
Lookers Park Royal Member Since: 19 Jun 2008 Location: London Posts: 338 ![]() ![]() |
I've got MM on my iPhone but not the 2012 version. Do you want me to check my settings etc?
James ![]() |
TJ101 Member Since: 30 May 2007 Location: Taunton Somerset Posts: 3752 ![]() ![]() ![]() |
Yep, also on a I phone as well as I Pad,,
Works well on both,, but not the latest version ![]() Main Brian James Trailer Dealer for South West UK |
thanks guys, please could you confirm the country you have set in the itunes account ?
I'll check when I get home, but deffo UK as my brother-in-law was trying to explain the virtures of his US iTunes account (re early releases etc) however he has to buy prepaid USD vouchers.
James ![]() |
Ditto to James,, Steve,, all on the home machine !! but sure its a UK account ?? California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2034 ![]() ![]() |
WTF is a Memory Map?
I'm on iOS5 and don't have this...I think ![]() 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Buzz Member Since: 11 Oct 2011 Location: Inverness Posts: 235 ![]() ![]() |
OS based navigational software. Very good. I use it and ViewRanger on iPad and iPhone. |
racer111 Member Since: 06 Jan 2012 Location: Hamburg Posts: 12 ![]() |
My brother has it but on an ipad, its meant to be really good and its definitely a UK account, sounds a bit weird why you could get it on an ipad and not the phone?
Check out zalando where I bought expensive red shoes Last edited by racer111 on 13th Feb 2014 11:59am. Edited 2 times in total |
I have mm2004 on my laptop and tablet, but there was/is an offer to upgrade to mm2012 so i bit the bullet and upgraded. i should be able to install on my iphone but itunes tells me it is not available in my country. i checked my account, might try and contact apple to see if there is a problem with my account.
so thanks for all the replies, and I'll keep the thread updated with any new findings |
Hope i am not stating the obvious Steve!!
I have my MM on loads of devises, home PC, 2 tough-books, as well as the i phone and Pad I am guessing you have bought the app via i Tunes ?? Then just load your maps from the PC, to the MM app in i tunes, then loads all to the phone and pad via the sync California F1, 75th 110 "Kermit", 50th Ann V8, 90 V8 Hybrid, 55 Series 1 Main Brian James Trailer Dealer for South West UK |
thanks Tim, this is what i did ...
from laptop, run itunes, logon to store and search for memory map app ... a message "application not available in your area" is displayed ... i have logged onto my account and checked the country, address and all looks ok i tried to search for memory map from my iphone .. memory map not found not sure what else to try ? |
coln18 Member Since: 01 Nov 2011 Location: Loch Lomond Posts: 45 ![]() ![]() |
I have the complete set of Great Britain memory map which i use on the lap top for my trekking and hill walking, i just print of the map i need for a particular walk and off i go, i didnt know you could transfer them onto portable devices.
Is it just iphones or is there an app for putting it onto an android phone? Col |
I've just tried again...
if i search the istore memory-map does not appear in the results if i go to the memory-map web site, and select iphone, it redirects me to istore but then i get the following message "Your request could not be completed." and "The item you've requested is not currently available in the UK store". I checked, I'm UK based and the message eludes to "UK" so I don't know .... |
if someone's got a minute, please could you try to see if memory-map is available in itunes store UK and let me know ?
