Home > Maintenance & Modifications > I fancy something diffent
Page 3 of 3 <123
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Sounds intresting. Does it sound like a TD5? How can you spot a 5 cylinder Transit?
Post #114483 11th Jan 2012 10:45pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
I'm not sure what it sounds like but I like the sound of 200 bhp as standard lol
You won't spot many but they have the engine in some what they call jumbo van ?
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #114484 11th Jan 2012 10:47pm
noogles
Brunei
I've been toying around with the idea of a Lexus v8 1uzfe. I hear they're quite cheap and pretty bulletproof.
Post #114521 12th Jan 2012 8:46am
dgardel
Italy
Re: I fancy something diffent
big steve wrote:
I fancy changing the engine n my truck does any one have any ideas I fancy the tdv6 but don't fancy the price
Any suggestions I could always go backwards to a td5 ?
Answers on a post card lol
Steve [/code]
WHY? Broken with Hybrid??? Rolling with laughter Rolling with laughter
but yes 5 cylinder tdci..3.2 200 hp out of the box not need to change the gearbox....
...at the beginning as well..... Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #114535 12th Jan 2012 9:29am
dgardel
Italy
http://www.ebay.co.uk/itm/TRANSIT-3-2-TDCI...1c2293ccf3
http://www.ebay.co.uk/itm/TRANSIT-ENGINE-3...3f0fb5f6cf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #114586 12th Jan 2012 2:08pm
big steve
Steve [/code]
I haven't broken anything just as I mainly run 35inch simex I want more power a lot more for off roading
Mybtruck has run fine with the turbo
Post #114721 12th Jan 2012 8:29pm
pannawonica
Australia
I like the idea of the 5 cylinder, larger engine lower EGT's and off boost torque. Nearer to the 3.9 Isusu CKD kits assembled here.
Post #114820 13th Jan 2012 5:43am
Sticky
England 2016 Defender 130 Puma 2.4 HCPU Stornoway Grey
I have a friend at Ricardo's who did the original engine work for Land Rover and also did all the ecu designs on the transit.
I remember him saying that Land Rover had to do quite a lot of modifications to the 2.4 from standard.
I seem to think he said a standard transit engine has a bunch of sensors in the engine that land rover had to remove as they sucked water in when submerged especially when the engine is hot.
Don't Land Rover make a fuss about oil scavenging in the 2.4 at extreme angles?
I personally would go the TDV6 because at least you know these same issues have been thought about for the D3.
Post #114832 13th Jan 2012 8:40am
big steve
Ok well surely all the switches and wiring are very similar so it wouldn't be hard to change these ?!?
Post #114993 13th Jan 2012 3:22pm
Way of life
Canada 1985 Defender 110 Puma 2.4 CSW Santorini Black
How did this build go?
I'm wanting to do the 3.2 into my Defender 2.4 just don't have what I like......power.
The 3.2 is on this side of the pond now but all the crap on it I want the UK/EU one.
Did you do the build can I ask you cost in real money.
Post #497247 28th Jan 2016 4:50am
Page 3 of 3 <123
