![]() | Home > Puma (Tdci) > Parking Brake Dash Light Problem |
The light is also the "low fluid level" indicator for the brake reservoir, just check level/wires still connected before panicking
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
Ours has done it on really steep descents before, maybe the fluid runs away from the sensor
mick Member Since: 08 Feb 2010 Location: Yorkshire Posts: 2109 ![]() ![]() ![]() |
Mine did it going down hill as said above your pads will be getting warn and the fluid has dropped
landroverdiver Member Since: 13 Jun 2009 Location: Renfrewshire Posts: 193 ![]() ![]() |
picked this up on the forum recently, my handbrake light flashed when going downhill.
small amount of dot 4 brake fluid in reservoir cured the problem. |
