![]() | Home > Puma (Tdci) > Are Puma windscreens glued? |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10387 ![]() ![]() |
They are possible, but in my career, all were tinted (green) ! QRZ 2e0vpf
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
I give up Matt, sorry but this is driving me nuts. It's good to help people out as others have helped me out in the past but this is ridiculous. It's ALL in the posts and links, what to get, where to get it, and how to do it, backed up by LR's own guide and others that have replied to you in your threadS about it. It's just confusing other people. Last go - It's not my way this IS how you put old style windows in, e.g. feed rubber onto frame, wipe detergent or similar onto rubber to make it slip easier, place window glass up against rubber and use tool to lift rubber over window lip and hey presto your window glass is in. You then seal with sealant, window to rubber and rubber to body then put in your insert if you have one that needs to go in e.g. your alpine windows. Why take it all out especially when the rubbers are only 10 months old. Just put your sealant tube in your caulking gun, cut the nozzle at an angle and squeeze a line of sealant under your rubber. It really is as simple as that.......just messy and fiddly.... Last edited by Zagato on 11th Jan 2012 6:02pm. Edited 1 time in total |
PLEASE ![]() |
Time for a beer, chill pill and pick up an old sit on lawn mower for my neighbour who wants to get into Lawn Mower racing in Pulborough with his son. Grass must be well kept down there
No mention of using a bit of cord to pull the lip of the seal over the glass or over the frame / body [depending on the window] Zag, I thought you knew everything
![]() There's a post that I submitted years ago [judging how young my lad looks in one or two] in the LR4x4.com tech archive regarding windscreen fitting to the last TD5 I had. I've done the job quite a few times myself but as the screen was being replaced under warranty and the guy didn't mind having photos taken I snapped away while he got on with it. I don't have time to copy my text but here are a selection of photos [hopefully roughly in the right order] which might throw some light on the subject form Matt: ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Doesn't show any sealant there but it was used. Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Yes used to use cord until I took out a rear SAAB 96 window (Very curved as you know being MOG!) and it just exploded in my hands when I was carrying it
![]() ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Dear Mr Zagato, dear Mr MOG and others
Having drained you of all your strength and pumped you (and MOG and...) for absolutely every scrap of knowledge on windscreen sealing, I would like to say an enormous "THANK YOU" ![]() ![]() ![]() My ACF-50 arrived today and (as it's actually dry in our work garage) I did my cappings and so can re-fit the chequerplate tomorrow knowing my beloved Defender won't fall to pieces behind it. I am now armed with enough information to confidently (really important when trying to explain like an idiot in German) discuss the options with Carglass and find out if I can get the correct (I now know what that is) sealant from them or elsewhere. I admit I am a bit of an information parasite but I hope that one day I will gain enough experience to be of help to others on this forum (apart from giving travel/hotel/skiing advice for Bavaria, to which all are welcome). I can also prescribe an extensive "chill pill" collection... but only in Germany (sorry) Thanks again and I wish all participants a wonderful evening ![]() Dr. Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2767 ![]() ![]() |
Do these sealants work when it's wet?
Reason I ask is, I replaced my windscreen seal back in October, and it seems the water is quite happily leaking in through it. So if I get some of this screen sealer stuff, can I squeeze it in under both libs of the seal even though there is currently lots of water sitting behind there? I figure the only way to dry it out properly would be to remove the screen and then re-fit it with the sealant in place? |
I'd still use grease in emergencies.
glad you are now fixed ![]() |
AlpsLandy Member Since: 11 Jan 2012 Location: Alps Posts: 116 ![]() ![]() |
Great thread - reason I just signed up to this site
![]() My 4 month old, MY11, 90 has multiple leaks from various holes and seals on the front bulkhead. Hoping the dealer will sort... but have downloaded the ingress guide (talks about 12 seater so not Puma specific?) and am also gonna do all the stuff in the 'Zag Corrosion Guide ' as soon as things dry up a bit. Thanks guys. 2011 Defender 90 SW 2006 Discovery 3 HSE Last edited by AlpsLandy on 12th Jan 2012 11:45am. Edited 1 time in total |
Bonjour !
Whereabout in the alps are you ? Got any snow yet ? |
