Home > Puma (Tdci) > Does anyone use a Radiator Muff during Winter?
Page 8 of 9 <123456789>
Yeah, I think so. Because the zips hold the flap taught, it's possible to fold the flap inside and then zip it down to the required level. I'll have a play later and take some more pics. Darren
Post #114237 11th Jan 2012 11:36am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Thumbs Up
Post #114246 11th Jan 2012 12:01pm
Happyoldgit
LandRoverAnorak wrote:
Here are a couple of pics in the daylight:
It made a very noticeable difference to the warm-up time this morning, with the needle moving off the bottom of the guage in about a quarter of a mile. Haven't done a long enough run to see if it needs to be left cracked open slightly yet.
I quite like the look of those and nearly bought one but the big eyelets put me off a bit. Still, if it does the job then Thumbs Up Steve.
http://forums.lr4x4.com
Post #114272 11th Jan 2012 1:26pm
Zagato
I like this one as it covers the whole of the grill as does the Exmoor Trim one, the others don't look quite right to me as they look too small. The big eyelets on this one kills it for me also though. I would probably go Exmoor Trim if I needed one...fixings can always be sorted easily!
Post #114273 11th Jan 2012 1:35pm
I doubt it without major surgery, to be honest. I bought one and sent it back as I thought it was so poor. Firstly, it clips around the top corners of the grill and, in order to get it tight enough to not fall off, it distorts the grill.
Secondly, the clips are designed to hook under the lower grill slats with the material of the muff trapped underneath. I found this arrangement to be really hit and miss and I was worried that it would just fall off.
Finally, it's incredibly easy to remove, which makes it very nickable Rolling Eyes
For best part of £50, it's a less than ideal solution.
As far as this new one goes, I've suggested to the vendor that he replace the eyelets with a velcro sealed slit to give access to the fixing, so it's possible that he'll change the design. Darren
Post #114282 11th Jan 2012 2:18pm
tolley
United Kingdom 2006 Defender 90 Td5 CSW Oslo Blue
do you think the canvas ones are any better
Post #114326 11th Jan 2012 4:28pm
Dunno, to be honest. I went for PVC as it's generally maintenance free. It seemed to be a fairly harsh environment for a bit of canvas to live, but I might be wrong.
As promised earlier, here's a picture of it partly open:
Whilst it seems instintively wrong, by folding the flap inside to the required height and pullling the zips down tight, it's actually very secure. I can't see any reason why it would move on the road. The light does, however, make it look like it's sprouted a beak Rolling Eyes
You do get a much wider opening than on other versions, so I suspect it could be a lot more closed than that to get a happy balance on the temperature front. Time will tell... Darren
Post #114331 11th Jan 2012 5:05pm
mk1collector
Sorry to drag this thread back up again but I had to share my brilliant experience dealing with globe roamer. After researching which radiator muff I liked the look of for the last couple of days I ended up seeing this thread and decided on the globe roamer muff. I looked at there website yesterday lunch and ordered at 1pm from the very helpfull Alex and it arrived at 11am today!!! Great communication and less than 24 hours from seeing their website to delivery. It's probably the best service I've had with any long distance purchase and the product fits perfectly.
Sorry for the esay but I was very impressed
Ray
Post #169423 19th Sep 2012 10:02pm
He's a very enthusiastic guy with some interesting ideas. Darren
Post #169427 19th Sep 2012 10:13pm
SteveS
England 2009 Defender 110 Puma 2.4 USW Santorini Black
Interestingly I used my Exmoor rad muff when I went to Arctic Norway/Finland last February in the TDCi. As an experiment I removed the muff at -40C temps and it made NO differnece to the temp guage reading - ie middle. The journeys were long/constant speed rather than stop/start.
To stop it being easily nicked and to make the lower edge sit nicely I put two tie wraps around the material to hold it taught to the grille.
This winter I will not bother to use it - it will be used more likely as a wading blanket......except last time I went over Salisbury I forgot to fit it and got a rad full of mud Big Cry
Post #169585 20th Sep 2012 8:23pm
T1G UP
i can't see the engine getting up to stat opening temps at -40! still put it on though as it couls stop the rad from getting blocked with ice etc?
Post #169590 20th Sep 2012 8:49pm
ZeDefender
Similar here - I couldn't tell last winter if it made any difference and I read so much theory on why it would or wouldn't work that it just goes on to keep the snow out. Okay - and it looks cool too Whistle
However... what I can say for sure, is that driving on the motorway with the muff even 1/2 done up is a bad idea - it choked the intercooler and killed the power really badly, even at -10 (I realised this Summer how inadequate the standard intercooler is on the motorway even in warm weather). I won't make that mistake again.
p.s. plus a certain respected tuner suggested that muffs might not be the best idea for modern intercooled engines... Tell someone you love them today because life is short.
Post #169594 20th Sep 2012 9:04pm
T1G UP
ok didn't think of that
Post #169605 20th Sep 2012 9:43pm
SteveS
Just talking from experience - i too doubt that the stat opened, or if it did then only slightly
Yes from the point of view of snow I would put probably have put it back on. However, with it being so cold it would hardly have mattered.....iced up disk brakes after an overnight stop were pretty exciting though Shocked
Post #169979 22nd Sep 2012 6:54pm
rossy
I remember this thread from last year and didn't like the aesthetic of a muff so I vowed to wear an extra layer instead or maybe a nice warm cardigan with an extra T-shirt perhaps. I'd rather look silly than my 110 look asphyxiated Laughing
Post #169981 22nd Sep 2012 6:59pm
