![]() | Home > Puma (Tdci) > Are Puma windscreens glued? |
| Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471
Yup, that's what I've used in the past too
Honestly Matt don't use grease! On older, out of warranty Defenders with non opening screens I've often resorted to a bead of sealant over the bulkhead to screen frame seal, it works well Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
| ZeDefender Member Since: 15 Sep 2011 Location: Munich Posts: 4731
Okay - I promise - no grease
But shout it at them in German because life is also terrifying and confusing... |
| GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10385
If it ain't broke...... QRZ 2e0vpf
| xatzhs Member Since: 12 Dec 2010 Location: Northumberland & Down South Posts: 258
On a Defender.... Probably just means you haven't noticed it's broken yet |
...it's not a Defender But shout it at them in German because life is also terrifying and confusing... |
| AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3709
This is what you need
http://www.sika.com.au/cmc/Datasheets/tds/SikaSwellS_tds.pdf 130's have feeling's as well you know |
Looks good too Blimey - perhaps we should have a window sealant database But shout it at them in German because life is also terrifying and confusing... Last edited by ZeDefender on 11th Jan 2012 2:53pm. Edited 1 time in total |
Definitely catchier than mine though! |
To be honest I'm just But shout it at them in German because life is also terrifying and confusing... |
The seal is just a length of closed cell foam which IIRC has a bit of self adhesive tape either side but in the past I've just used a length from a roll without the sticky tape which can be bought from extrusion / trim supplies. TBH the older they are the more likely they are to break down and act like a sponge so I can't see the harm in running a neat bead of something over the top and around the sides - just as long as it's dry underneath. Steve.
Thanks - so for now I'll cover it in butyl (the blue-tacky type) - I love the stuff We had an old caravan which sprang a leak in Croatia. All I had to do was scrape off some excess (15 year old!) butyl underneath one corner, work it a bit and stick it over the crack. It was still there a year later when we sold it But shout it at them in German because life is also terrifying and confusing... |
| Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026
Yes seal it, you don't want water sitting under your rubber rotting the metal away where any paint has been scraped off whilst fitting the window or into any of the frame joins! My 5 year old TD5 frame had holes in it from this It's all in the corrosion guide Look at the Puma water ingress manual, may have to Google it, says "sealing windows, glass to rubber, rubber to body" etc etc! It's all in there, it's not hard to do, only takes a day to do it all |
I seem to have downloaded a copy where the windscreen wasn't mentioned Must check again I agree with everything you say but the OCD in me still wonders if taking it all to pieces and sealing everything on assembly (if possible) might be However, I'm slowly being convinced to do it your way - and it's stopped raining for a while Go on, shout at me p.s. plus I'm rubbish and messy at any kind of sealing/painting - you would But shout it at them in German because life is also terrifying and confusing... |
