![]() | Home > Puma (Tdci) > Android Torque and ODB2 socket location |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
Directly under the steering wheel there is the fuse compartment it's in there just use acorn to undo the two locks
Regards Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
| bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189
Thanks Steve.
does'nt look like there is a lot of space to have a cable hooked up permanently? Thinking Scangauge now! BM52 |
| K9F Member Since: 12 Nov 2009 Location: Bournemouth Posts: 9610
bm52,
Have a look here for mounting and connection ideas you may wish to consider. http://www.defender2.net/forum/topic3719.html?highlight=scangauge And... http://www.defender2.net/forum/topic4510.html?highlight=scangauge If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
KF9 - thank you. reading posts now. BM52
| All times are GMT |
