![]() | Home > Puma (Tdci) > Part number ? |
| MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2511
http://www.defender2.net/forum/topic5282.html Puma 110" SW
| ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1864
Hi Steve,
I swapped mine for a new one last summer as I suspected it was faulty - not a bit of change, disconnected the egr at the valve, performance returned and I live with the yellow light until I can get my act together and get a remap. Keith |
| big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456
Yer problem is that mine has a temperature probe problem so I do need a new one
Regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
Some onmust know it 2015 2.2 tdci hardtop xs
| bell-auto-services Member Since: 08 Jul 2007 Location: North Yorkshire Posts: 2233
MHK501040
Pete |
Steve,
Firstly have you got one or do you need my spare? Secondly, you say you have a temp problem, have you got a scangauge fitted and if so has the inlet air temp gone wrong? Cheers Keith |
| Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Remember as well there are two separate sensors in the MAF. One deals with the Ambient air temp and the other is used by the EMS to indicate air flow to be used in fuelling calculations by the EMS. So you can theoretically have a working Hot film sensor feeding the correct info to the EMS but have a faulty AAT which doesn't really affect the fuelling calculations. On the other hand a knackered Hot film sending spurious readings to the EMS causing high fuel use and other issues can be dismissed by some as the AAT is working so that must mean the MAF sensor is working fine when it is not.
Brian. |
| All times are GMT |
