Home > Maintenance & Modifications > Optima batteries which ones.
Page 4 of 4 <1234
leeds
Errr Yes and No
The standard tray is not wide enough for 1700 so that is the NO bit
The YES bit is that the lips would have to be cut off.
However I think the Gwyn Lewis ones might do it without modification. May I suggest you contact Gwyn and check?
Brendan
Post #112593 5th Jan 2012 8:43pm
T1G UP
leeds wrote:
Errr Yes and No
Brendan
Gwyns looks OK SS as well which is nice. i've messaged D44 about the size theres will take.
Post #112615 5th Jan 2012 9:31pm
leeds
The Devon will take twin Odyssey 1500 at maximum.
Can measure a twin battery in morning if I remember.
Brendan
Post #112645 5th Jan 2012 10:02pm
T1G UP
Brendan
i guess you didn't!
Post #113218 7th Jan 2012 4:26pm
Brendan didn't say which morning Shocked
Post #113226 7th Jan 2012 4:53pm
T1G UP
true.... a bit like my list!
Post #113229 7th Jan 2012 5:03pm
leeds
Oi you two. BEHAVE!
BPman has already been sent to the naughty step.
T1G you will be for the naughty corner very soon if you are not careful!
Brendan
Post #113238 7th Jan 2012 5:22pm
I'm off it now ... reading up on cold climate effects on automotive electrical systems
Post #113244 7th Jan 2012 5:35pm
T1G UP
leeds wrote:
Oi you two. BEHAVE!
Brendan
Rolling with laughter i'm in the dog house with her so whats new
Post #113270 7th Jan 2012 6:52pm
Tompoole
England 2004 Defender 90 Td5 CSW Java Black
have tmax split charge red and yellow optimas ok on long runs but stop and starting 15 times a day in cold weather and running a pump of the yellow top, i find myself having to charge the batteries every 3 days.
during summer I charge very week. but on long trips the system copes well. not sure if this is an optima problem or the cheap split charger.
ill be the one that asks , whats the issue with optimas? Have fun be happy
Post #113272 7th Jan 2012 6:53pm
leeds
YES have measured the twin battery tray.
Size is ca. 345 x 255mm with an 18mm upstand.
I think you will find that is the size of the Devon trays as well
Brendan
Post #113790 9th Jan 2012 7:03pm
Brendan
thanks Brendan, I have emailed my friends in Oslo to find out about current draw for 12v electric blankets, from what I have seen on the web, 36-50watt, more details to follow. so I may be fine with 1500's ...
Post #113802 9th Jan 2012 7:32pm
paulcnn
Malta 1994 Defender 90 Td5 HT Barolo Black
Any reviews ? Which batteries lasted longer than 5 years ?
Whats system lasted longer OPTIMA or Odyssey
BigMike wrote:
Zagato wrote:
I thought Optima batteries were outdated, superceded with a more advanced battery/brand! Have read a couple of threads on this but don't can't remember the make as I would never need them! Will do a search on another forum Confused
Optima is yet another in the same stable as BFG etc as a "must have" thing based on previous reputation going years back which is now no longer warranted with better, cheaper products out there. There are FAR better batteries out there like varta, yuasa, unipart, numax. cranking amps on a defender are not that high, a calcium unipart is perfect for example. Numax too are good, VERY good in fact for running fridges and accessories from.
a fantastic source of really good, simple stuff re batteries and split charges etc is www.adverc.co.uk I've been using these products now for two years. They're robust, don't fail in extreme temps and just..work. plus they are really helpful.
Post #1051943 16th Nov 2024 10:33pm
Page 4 of 4 <1234
