![]() | Home > Td5 > Wiper Motor |
pom Member Since: 01 Jun 2010 Location: Worcester Posts: 1343 ![]() |
ive got a nasty feeling its a dash off job. I had to get my screen washer replaced last winter and they removed the dash to do that
![]() Pom |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 ![]() ![]() ![]() |
yep dashboard jobby
![]() ![]() ![]() Click image to enlarge pic of my old 90 200tdi wiper motor is roughly in the same place ![]() |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Depends on the age of the TD5. If its pre 2002 then its very easy, if its post 2002 the a little more difficult. No need to take the dash off though. Once a few bits are off and the screws are taken out there is enough give in the dash to get the motor out without removing the dash. Once you have done it once its easy!
Pete. |
yer try it yourself first mate if you get stuck take it to a local garage worth trying save on the £££££'s
WarPig Member Since: 05 Dec 2009 Location: Sheffield Posts: 1748 ![]() ![]() ![]() |
Killer, your photo isnt showing for me, could you repost please?
![]() Click image to enlarge there we are has that worked mate if not try the link ![]() ![]() http://i52.tinypic.com/2wnr12c.jpg |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8321 ![]() ![]() ![]() |
before you go the new motor route just check the spindles that come through the bulkhead havent seized.
remove motor and try and actuate the worm by hand, if it doesnt turn the spindles then change them, only about £7 each but that is a dash off job! Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
dnorrishill Member Since: 15 Jul 2011 Location: Hampshire Posts: 629 ![]() ![]() ![]() |
This is exactly what happened to me on my 03 plate TD5 90 2 days before the MOT!! Had spindles replaced and all's well now. |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 ![]() ![]() ![]() |
mikeyp, depending on where you are in Ldn, if you get stuck, I can't recommend Foley's enough although there are prob plenty of independent's closer to you
![]() http://www.foleyspecialistvehicles.co.uk/ |
hey seb i work for foleys i thought i recognised your landy were abouts in essex are you
Hello Killer! I'm near Ongar. My 110 was in recently for a new wiper park switch and dead driver's door window motor.
haha sweet good to hear the great feedback
![]() ![]() ![]() Click image to enlarge (if you hadnt guessed thats my one ![]() |
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5026 ![]() ![]() |
What make is your steering guard Killer?
Visited Foleys about 10 years ago - good blokes ![]() |
im not sure i know that terrafirma make one which is very similar mechanic fitted one today at work looks just as good
