![]() | Home > Technical > Tyre sizes for 110 and Gearing issues? |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8338 ![]() ![]() ![]() |
235.85R16 and 265.74R16 are both pretty much the same as 750.
(235 (width)x 0.85(aspect ratio) x 2 )/25.4 + 16 = tyre height in inches 31.10.50x15 = 31" tyre height, 10.5" wide on 15" rim Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
http://www.1010tires.com/tiresizecalculator.asp
http://www.miata.net/garage/tirecalc.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
a td5 will pull the gearing fine with 285's. not sure about a 300 110. a puma has a lower first gear so again i can't see any issues
I've got the Insa Turbo Dakkars on mine in 265/75 16, while they're not to bad on the road handling wise just be aware that it's like having a set of military bar grips on for noise
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17876 ![]() ![]() ![]() |
I am running 285/75x16 KL71s on my Puma 110 with no issues. The speedo is spot on measured with a Robic (home office approved) device, and I usually pull away from rest in 2nd.
