Home > Maintenance & Modifications > puma transmission upgrades
Page 2 of 2 <12
Just the front sofar (because the original disintegrated). Planning to fit an Ashcroft locker in the back when funds permit.
Post #111761 3rd Jan 2012 6:29pm
Naks
Thanks. Does Ashcroft not make stronger diffs for the Puma? --
Post #112006 4th Jan 2012 2:00pm
ibexman
For not much more than the price of a4pin diff get a arb or ashcroft locker in there sorted Thumbs Up
Post #112012 4th Jan 2012 2:22pm
Replacement front diff from LR (4-pinion since the 2-pinion is no longer sold for this application) collected from dealer: £1250.
Replacement torque biasing front diff from Ashcroft c/w with heavy duty crownwheel & pinion including delivery etc: £888
Both prices are outright sales, if you return the old diff to Ashcroft you'll get £90 back.
It really isn't a difficult decision!
Ashcroft Transmissions can supply normal 4-pinion diffs, automatic torque biasing diffs (their own or Quaife), and full locking diffs (their own or ARB) for all wheelbases of Puma, either front or rear. All these are available with optional heavy-duty crownwheel and pinion sets, and you can have the diff pegged if you want too. Details on their website.
I opted for the Ashcroft automatic torque biasing diff with HD crownwheel & pinion, for little more than half the price of a replacement open diff from Landrover. It was also nice to see engineer's blue on the teeth when it arrived, showing that the tooth engagement had been properly set up. Many Landrover diffs recently have not been at all well built!
Post #112024 4th Jan 2012 3:20pm
Naks
blackwolf wrote:
It really isn't a difficult decision!!
yeah, but shipping to RSA is a killer... --
Post #112025 4th Jan 2012 3:22pm
Sorry, I hadn't noticed your location!
Post #112033 4th Jan 2012 3:58pm
MK
Detroit Trutrac is also a choice and good value. Puma 110" SW
Post #112053 4th Jan 2012 5:06pm
Naks
Thing is, I don't necessarily want a TruTrac/Arb locker. I just want a standard diff that won't break in another 29,000km.
Since I do mostly overlanding, if something goes wrong in the bush, it's easier to find a village workshop that knows the standard LR parts than some complicated aftermarket part. --
Post #112313 5th Jan 2012 9:16am
MK
Truetrac (is not a Detroit locker) is a very simple and strong bit for US$450. I agree, an ARB has some seals which can fail (unlikely) and costs the double. A std 4-pin LR would do the job for sure (what cost?).
Any how, why did the diff fail? Puma 110" SW
Post #112380 5th Jan 2012 12:04pm
Naks
MK wrote:
A std 4-pin LR would do the job for sure (what cost?). Any how, why did the diff fail?
It has not failed yet. Just the low-frequency drone you hear when you lift off which is the first symptom that it's on its way out. Sad --
Post #112381 5th Jan 2012 12:06pm
MK
Perhaps a pinion-crown adjustment would save the diff. Puma 110" SW
Post #112383 5th Jan 2012 12:09pm
sorgum
Turkey 1994 Defender 110 V8 Petrol SW Auto Pennine Grey
Completely manual, non-electronic automatic transmission
Completely manual, non-electronic automatic transmission conversion;
Application of the 4HP22 automatic transmission, which also does not contain electronics, onto a 1988 model vehicle with a V184 engine that does not require an ECU.
Defender
 Defender - Defender Parts
Post #1040899 24th Jul 2024 2:16pm
Page 2 of 2 <12
