![]() | Home > Puma (Tdci) > clunking gear change and lots of other issues |
I have actually welcomed the cold weather (!) here, as changing gear has become a lot more pleasant (at least until the oil warms up). The Motul oil also brought a significant improvement. I can live with an iffy gearbox as long as it doesn't keep getting worse. In any event, I'm already saving for an HD Transit box from Ashcroft when the warranty expires - I just hope Ashcroft are still in business in 2 years ![]() But shout it at them in German because life is also terrifying and confusing... |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3472 ![]() ![]() ![]() |
But your gearbox may not give up the ghost in two years, it might continue functioning for 22 - or might give up in 12 months - who knows? Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
Preferably the former, as long as somewhere like Ashcroft still exists in 22+ years ![]() But shout it at them in German because life is also terrifying and confusing... |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2682 ![]() ![]() ![]() |
Finally the gearbox is getting attended to, and the agent has ordered a new gearbox just in case.
Now when I take my foot off the accelerator at 110-110kmh, there's a whoop-whoop sound that seems to come from the rear diff ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
The very best of luck to you sir ![]() I, for one, am waiting with baited breath to hear the outcome ![]() Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Thanks!
wrt the diff, I saw this on another forum, can anyone confirm? -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Finally, after a whole year of battling with LR South Africa, their technical advisor does one drive and tells the dealer to replace the gearbox.
So just under 30,000km the landy gets a new rear diff and a new gearbox ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17991 ![]() ![]() ![]() |
Dave, I would be delighted to volunteer my DC as a testbed for your rear diff - it would complement the ATB HD front diff I bought from you in December!
Only 2 years to go 'til I'm out of warranty and into some serious upgrades
pannawonica Member Since: 21 Nov 2010 Location: Clackline Western Australia Posts: 568 ![]() ![]() |
Force 9's and the heavy duty transit upgrade gearbox seem to be the Rolls Royce solution. While I am on the subject a larger engine 5 cylinder Puma would the way to go, not the car like D4. Commercial type engine, bullet proof so to speak.
There's been a lot of talk here and elsewhere about the possibility of fitting the Transit HD gearbox, but has anyone actually done it? If so, is it actually any better? |
[quote="blackwolf"][quote="pannawonica"]Force 9's and the heavy duty transit upgrade gearbox seem to be the Rolls Royce solution. While I am on the subject a larger engine 5 cylinder Puma would the way to go, not the car like D4. Commercial type engine, bullet proof so to speak.[/quote]
There's been a lot of talk here and elsewhere about the possibility of fitting the Transit HD gearbox, but has anyone actually done it? If so, is it actually any better?[/quote] Maybe white vanman can come in and put us right. ![]() |
ashtrans Site Sponsor Member Since: 08 Nov 2008 Location: Harpenden Posts: 264 ![]() ![]() |
no, not been done yet, the 3.2 TDCi 5Cyl transit MT82 is rated to a higher torque capacity, I did some digging to find out the differences and have found that at least 3 (maybe more) of the bearings are much bigger, the 2 boxes are similar in many ways and it looks possible to put the 4 wheel drive back end onto the HD transit box. There is some debate if the main casing is the same, I don't know yet, we have a customer who is putting this 3.2 TDCi into a defender and will be sending me the HD MT82 to try and convert to 4WD spec, I will advise the outcome, if this is a goer I can get brand new HD MT82's from ford at reasonable money, the last 7 failures I have seen on the defender MT82's are : 1 x stripped reverse dog teeth (ramming into reverse) 2 x failed bearings (plain hard work, ie towing digger) 1 x bust props smashing casings (bad prop UJ) 3 x stuck ingear (being heavy handed with shifter) the HD box will only help with the failed bearings Dave |
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
i think this will be amazing! |
