Home > Puma (Tdci) > cappings rust
boxer
United Kingdom 1990 Defender 90 200 Tdi HT Coniston Green
cappings rust
hi all last week i picked up a new 61 plate xs station wagon and i love it, traded in a freelander 2 sd4 hse good car but not a defender.I was very happy until i spotted a 2008 defender with rusty cappings my question is is this common?ps excellent forum keep it up.
Post #110964 30th Dec 2011 10:59pm
we did a factory visit to see the defenders being built, yes, expect rust from the cappings unless you get to the areas quickly ... where's Zag when you need a full explanation ?
Post #110968 30th Dec 2011 11:09pm
Zagato
Yawn Morning, hangover already! ........ As Steve says, it was confirmed that the underside of the capping's is not painted so a good spray with ACF-50 then Dinitrol will cure and prevent any rot. As per the water ingress manual it would then be a good idea to seal your end capping's with window sealant. Do your rivets at the same time, they can corrode on the inside and around the edges Thumbs Up
Many threads on what to do with your new Defender, under-sealing in particular and strongly suggest you do it before any salt gets to it. Once salt has got to the chassis you can never properly get it off especially from the inside.
Enjoy Thumbs Up
Copied from another thread...
Dinitrol used for the underside nooks and crannies, relevant mechanicals and use the extension nozzle for the chassis insides, rear cross-member, door pillars, bulkhead front and inside, doors, etc, and other sprays, sealants for under ALL the capping's, between the body joins e.g. window and bulkhead seals, main body and sides, sides and roof. Also around the unpainted rivets, front window hinges, bonnet hinges, gutter seams, mirror arms, rear window catches, wiper arm exit points, both water jets, lower ali front panel, steps etc etc and do the interior seat frames/brackets that rust from the outset any nut's bolts you can see and those under the carpets etc and lower seat belt fixing as they can rust within the year! and in and around the bottom rivets holding the lower door seals in place under the rubber etc (not with Waxoyl though it will ripple them out of shape!), headlight rims, and all the external front screws etc etc Oh and door hinges, under the bonnet, cylinders, brackets, electrics, common rail etc etc, avoiding the belt and pulleys!
Too much to detail but it's simply a case of going around the vehicle methodically and either using an underbody anti-rust stuff for bit's you won't see e.g. Dinitrol and stuff like Wurth Anti Corrosion Wax & ACF-50 for the bits you do (one remains a wax the other remains greasy!) & a windscreen sealant and a pot of Dum Dum will see you right for everything else. Where to put some Dum Dum, sealants etc are listed in the Water Ingress Manual https://www.defender2.net/gallery/albums/us...cedure.pdf It's a satisfying job as well Just need to get underneath down and dirty and I suggest you wear a mask and overalls. Window sealant is best done by your local window fitter as it's a messy tricky job
You don't have to do any of this of course but you will have water sitting under your window rubbers rotting away unseen, probable leaks and rusting of pretty well everything underneath the body - not a problem if you are not going to keep the vehicle long term of course. The Defender is the only LR in the range that is NOT undersealed for protection!
To summarize this kit http://www.rejel.com/rejel-store/list/1/productid/9408.aspx
and a couple of cans of this http://www.acf-50.co.uk/acf50.htm
and call in your local window fitter to seal your windows will do the job Can be done in day
Post #110991 31st Dec 2011 9:27am
cheers Zag Thumbs Up
Post #110993 31st Dec 2011 9:40am
T1G UP
I had what i thought were rust stains on the side of my 110 after a week Big Cry it was infact sealing wax! so they have changed there preotection program some when late 2011 /12 MY.
I will be re doing those areas in the spring.
Did have some pics but running a new laptop and haven't moved all the files over yet.
Post #111006 31st Dec 2011 10:25am
Happyoldgit
Excellent advice. The forum really does need a sticky thread regarding inhibiting corrosion. Steve.
Ineos Grenadier Trialmaster but owned numerous Land Rover vehicles of all shapes and sizes over the decades.
Current Defender: A non tarts hand-bagged Puma 110 XS USW.. Now long gone.
http://forums.lr4x4.com
Post #111016 31st Dec 2011 11:04am
Zagato
Right I'll get onto it MOG Thumbs Up
Post #111022 31st Dec 2011 11:32am
boxer
Thanks for the good advice i got it wax oiled at the dealer before pick up.They have done underside only,as soon as the good weather comes i will be straight at it with ditrol etc.Zag do you mean spray up under the small gap between cap and body work? is the spray pipe fine on the ditrol cans?
Post #111026 31st Dec 2011 11:50am
Happyoldgit
Good man, chop chop! Steve.
Post #111040 31st Dec 2011 12:51pm
Zagato
Boxer, yes in the gap, Dinitrol cans and ACF-50 details here "Corrosion Prevention guide"
http://www.defender2.net/forum/topic10467.html
Thumbs Up
Post #111056 31st Dec 2011 2:19pm
