Home > Puma (Tdci) > Central Locking
churchy
2007 Defender 110 Puma 2.4 XS CSW Java Black
Central Locking
Merry Christmas!
Had a weird one today - doing the usual last minute shop and locked the wagon with the key fob - checked all doors and the rear drivers side remained unlocked.
Locks perfectly well when I push the button down but not with the remote - best to take off the door card and check the mechanics I guess?
Assume its not a faulty central locking pump as all the others incl rear door work fine.
cheers
Churchy
Post #109762 24th Dec 2011 4:43pm
Broken wire between the door and B post (where it flexes) without a doubt. About number 4 on the list of faults that always happen sooner or later!
Happy Christmas!
Post #109764 24th Dec 2011 4:54pm
Mine used to do that, it just went slow and didn't go down all the way, so I took the panel off and sprayed light lube into the actuator.....works every time now, jobs a fish Thumbs Up QRZ 2e0vpf
Post #109773 24th Dec 2011 5:32pm
churchy
Great thank you - will investigate both & post back the fix - fingers x!
Post #109780 24th Dec 2011 6:00pm
ickle
Try gently pulling on the two wires from the hole in the B post, mine did the same last week and they both were broken totally through, about halfway through the trunking to the door only a 20 minute fix though Thumbs Up
Post #109784 24th Dec 2011 6:16pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Brill info guys!
have had the same start to happen to my offside passenger door when in Sweeden this year - so will have a play when I get home and see if it can be fixed! Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #109938 25th Dec 2011 11:12am
churchy
Hi all,
Central locking still working intermittently however yesterday the back drivers side door wouldn't open at all.
Drove over to the folks house - parked up tried it again and it all worked from the inside and outside handles but the door locking knob is now loose and does not seem connected to anything.
Tried popping the door card off today and freed all the plastic clips round the outside but couldn't get the window winder off - surely not hard?!? Can I pop it off with a small screwdriver and does it have a retaining screw under the round end?
Once I can get the door card off I can have a good route around - check wiring for central locking for breaks or poor connections, sort locking knob, lube all working parts and hope to fix it.
thanks again
Churchy
Post #110298 27th Dec 2011 11:22pm
ickle
There's a spring clip held in a groove on the handle, put a old blunt screwdriver between the handle and flat plastic disc and gently twist so you can see the clip, pull this out parrallel to the door and the handle will fall off.
Put the clip back onto the handle and snap back into place on refitting, remember to have the handle parrallel to the ground so its weight is trying to close the window....
Keith
Post #110299 27th Dec 2011 11:31pm
churchy
Great thank you - late night on the forum and still an answer! Brilliant.
I spotted the clip but left it as I have a habit of seeing them fly off never to be seen again!
Will have a go in the morning.
Thank you.
Post #110302 27th Dec 2011 11:39pm
Clips look like this and always fit this way so you know which way push.... Just put a finger so it doesn't ping into orbit....
 QRZ 2e0vpf
Post #110305 28th Dec 2011 12:13am
JWL
A length of cotton rag can work wonders and not leave any screwdriver miss gougemarks. Pull up a 12" length of the material up from the knob end holding each end and apply pressure to the underneath parallel to the door card and gently saw away. The material snags the prongs of the clip and dislodges it letting the handle move free of the splines, takes a bit of practice but when you've got the knack is very quick and mark free Thumbs Up
Post #110311 28th Dec 2011 1:01am
ickle
Hey thats a good tip - I'll try that the next time something breaks, falls off, rattles etc...........
Keith Thumbs Up Thumbs Up
Post #110410 28th Dec 2011 6:56pm
Lukey Boy
United Kingdom 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
As Blackwolf said probably a broken wire. Check the wire inside the gater that runs from the B pillar to the door. Thats where mine had broken! Thumbs Up 2008 110 XS CSW Stornoway Grey
Post #110413 28th Dec 2011 7:08pm
60North110
2007 Defender 110 Puma 2.4 CSW Java Black
Cheers Greeni, read this thread and found one of my rear doors was not locking - same problem and fix as you quoted.
Would never have realised this, had it not been for the forum.
Thanks Thumbs Up
Post #113652 8th Jan 2012 11:16pm
churchy
Finally got round to this job today however too late to finish as the light fades.
Pair of old boxer shorts did the trick with the window winder removal so thanks for that tip!
However now the door card seems to be stuck around the door locking knob somewhere - surely can't be this difficult!
Any ideas?
cheers
Churchy
Post #115016 13th Jan 2012 4:58pm
