Home > Maintenance & Modifications > puma transmission upgrades
Page 1 of 3 123>
paulgrs2
United Kingdom 1988 Defender 110 200 Tdi PU Baltic Blue
Has anyone had there puma gearbox, t/box and/or diffs strengthened? If so any recommendations?
Thanks in advance. Very Happy
Post #109013 21st Dec 2011 10:32pm
T1G UP
Re: puma transmission upgrades
you can upgrade to 4 pin diffs. tb and gearbox are strong enough i'd say.
Post #109019 21st Dec 2011 10:36pm
paulgrs2
Any idea of what the upper limit torque wise the g/box and t/box can sensibly cope with? Road use car mainly.
Post #109023 21st Dec 2011 10:54pm
T1G UP
not a clue! why do you ask?
Post #109025 21st Dec 2011 11:05pm
paulgrs2
Just planning a project I am doing next year with a 110 build and need to factor the transmission into the engine output.
Post #109028 21st Dec 2011 11:12pm
ZeDefender
There has been some discussion about the Puma gearbox (aka "MT82" and made in China)
Many people don't have problems... mine is crap and quite a number are replaced under warranty.
Ashcroft are beginning to rebuild the standard MT82 and may be able to provide an HD version (from the Transit) at some point in the future.
Incredibly, Ford also put the MT82 into their newer Mustangs Shocked and there are now a lot of Censored off Mustang owners with undriveable cars Big Cry See:
http://mustangsdaily.com/blog/2011/11/09/f...nsmission/
Ford clearly have some issues to sort out... Tell someone you love them today because life is short.
Post #109030 21st Dec 2011 11:21pm
T1G UP
speak to pete bell about either 5 cyl tdci, tdv6 or tdv8 as he's done them..well not the 5 cylinder yet on a manual box although i believe it was a D3 manual box
And IMHO autos the way to go!
Post #109031 21st Dec 2011 11:23pm
paulgrs2
Bit of a petrolhead myself so probably going that route rather than the fluid of satan lol.
Post #109039 22nd Dec 2011 12:02am
Puma 2-pinion front diff is definitely NOT up to the job - just replaced my seized and disintegrated unit with an Ashcroft ATB diff. Details and photos on another thread.
Replacing the diff has improved the gearchange enormously.
Post #109072 22nd Dec 2011 9:54am
MK
360 Nm max torque (nominal) Puma 110" SW
Post #109084 22nd Dec 2011 11:27am
T1G UP
then look at the zulu! i's personally go LS1 with te80 box and atlas twin stick transfer so rwd as a daily and 4wd for the wet.
Post #109113 22nd Dec 2011 2:27pm
ibexman
[quote="blackwolf"]Puma 2-pinion front diff is definitely NOT up to the job - just replaced my seized and disintegrated unit with an Ashcroft ATB diff. Details and photos on another thread.
Replacing the diff has improved the gearchange enormously. ......how can changing a diff improve your gear change Rolling with laughter Rolling with laughter
Post #109129 22nd Dec 2011 4:10pm
The Puma's notoriously variable gearchange is greatly affected by driveline faults especially backlash. When I bought mine the gearchange was awful, a replacement clutch of the new type was big improvement but it still wasn't great, replacing worn rear halfshafts and drive flanges made a further improvement, but after changing the diff I finally have a really good gearchange; it is smooth, progressive, and doesn't snatch or clunk at all.
Post #109142 22nd Dec 2011 5:39pm
paulgrs2
Ain`t won the lottery lol.
Post #109228 22nd Dec 2011 7:54pm
Naks
That's very interesting. Did you get new front and rear diffs or just the front? --
Post #111680 3rd Jan 2012 11:59am
Page 1 of 3 123>
