Home > Maintenance & Modifications > What have you fitted, you wouldn't fit again...
Page 7 of 10 <12345678910>
I don't have roof lights now (or yet) Shocked
But I have had.....
They'd look stupid on my old 'M' !
Thumbs Up QRZ 2e0vpf
Post #108755 20th Dec 2011 6:08pm
BigMike
re cool boxes, not only will they drain your battery, they are designed to keep the temperature inside around 20 degrees below ambient, NOT to keep the inside at say, 4 degrees c (normal fridge temp). Fine in the UK I suppose, not so fine in the Moroccan desert. Hello Salmonella, goodbye innards.
Post #108756 20th Dec 2011 6:10pm
leeds
Grockle wrote:
a condensing boiler,waste of bloody money
There is also a basic design fault with condensing boilers! The condensate is piped out of the boiler normally through a 15 mm pipe.
Oh dear they suddenly realise people walking by might get scalded. Shock horror.
So the condensate must be piped to a drain down a 15 or 20mm pipe.
When do you want a CH boiler to work?
When it is rather cold, i.e. below freezing outside.
What happens then? The condensate is water, water cooled below 0C turns into ice. The condensate pipe is then blocked and your boiler starts to 'leak'
Oddly enough they only realised that over the last few cold spells.
Ho humm they are energy efficient boilers ok. Yes the may leak, cause electrical problems, ruin your decorations but the EC dictates that we must have them
Lets all Bow down to the all wise, all knowing ferking useless beaurocrats in Brussels
Brendan
PS Would you notice the leaks if you had a condensing boiler fitted to your Defender
Post #108759 20th Dec 2011 6:25pm
d j hutton
England 2011 Defender 110 Puma 2.4 USW Orkney Grey
Quote:
The 12v cool boxes are NOT to be recommended if you are running a single battery setup as they can drain a battery overnight
I sussed that out a while ago Laughing good job I had a dual battery set up or else we would have been pushing off the ferry! Took me a while to work out that it was the cool box and not the split charge set up - duh (damm no nothing newbies!)
I think my old man has a gas/12v fridge hidden in the garage so I'm going to try that out first on a few local trips and then probably end up doing what I should have done two years ago - BUY A PROPER JOB!
Having spent out on a new wagon a fridge is a drop in the ocean I guess.
What sort of money do I need to spend to get a decent smallish one?, nothing massive, and recommendations for suppliers.
(I haven't seen the wifes full pressie list but I'm sure that 'perfume' could be misread as 'fridge' Whistle )
DJ
DJ 1989 200tdi 90 csw
2011 110 usw Orkney grey
Buy British 🇬🇧
Defender Clothing Designs available at http://www.rangesports.com/acatalog/Defender-Stuff.html
Post #108761 20th Dec 2011 6:27pm
leeds wrote:
Stick one in a vehicle, take out at every campsite could also become a PITA if you were moving frequently.
I'd definitely agree with that. Bolt it in and leave it there, unless there's a damn good reason not to. Darren
Post #108763 20th Dec 2011 6:28pm
leeds
The three main brands of 4 x 4 fridges are National Luna, Engel and ARB.
There are lots of different things to consider when buying a fridge apart from price. Useful volume, current draw, temperature set, battery monitoring etc. Please remember I am a trader and can always be accused of being biased.
Useful volume is around the 40-50 llitres.
So prices and some comments from personal experience
Engel MT45 £700 This fridge is a 40 litre fridge, is well regarded and we have used one on our travels. Is let down by lack of battery monitor and the way you set the temperature.
ARB 47 fridge £760 This fridge is a 47 litre fridge, we have also used this one extensively. Has a marginally larger footprint then the Engel, better temperature setting, better control layout and more user friendly in our opinion
National Luna S295. £1,000 A 40 litre fridge, highly regarded by the S Africans. Have not used one personally, so could only repeat sales patter.
If you go lower in size, say to a 30 litre fridge you will only save about a £100-150.
Our personal favourite is the ARB 47 litre one and is the one we stock.
If you come to any show we will have both the Engel and the ARB displayed so you can then make your own informed decision
Brendan
Post #108768 20th Dec 2011 6:52pm
Surrey Rover
[quote="d j hutton"]
I bought an Engel 35ltr a while back for around £500 from memory (think they have gone up) it's been bashed and battered and works perfectly each time everytime. It has even saved my bacon when my very expensive Maytag broke twice and we needed the basics to still be refrigerated. Nick
2.2 110 Tipper
Post #108770 20th Dec 2011 7:00pm
Getting back to the OP, I've gradually reached the conclusion that full roof racks are largely unneccessary. I love the look of them and have had several on different vehicles over the years (Brownchurch, Safety Devices, Patriot and OE Land Rover). Some have even had roof lights on them Wink However, for a vehicle that's genuinely dual purpose, in that it's both my daily driver and used for more adventurous stuff, I'm finding roof bars to be a good compromise. They can be used to carry all of the usual off-road paraphenalier as well as more domestic stuff, but can also be easily removed and stored when not needed. Darren
Post #108771 20th Dec 2011 7:00pm
DefenderOfTheEarth
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
You can also fit in some car parks without a roof rack. With one, no chance.
I'm not keen - I'd fit roof bars too if I had to. But TBH, if you can't fit everything IN a 110 or 130, you have too much stuff! Rooftents excepted of course... Defender 110XS SW gone... now VW California 180 4 Motion.
Post #108800 20th Dec 2011 8:58pm
Oztent goes on the roof. It will fit inside, just, but then the kids would have to be strapped to the roof instead. Hmm, now there's an idea... Laughing Darren
Post #108811 20th Dec 2011 9:34pm
18stone
England 2011 Defender 110 Puma 2.4 USW Zermatt Silver
These threads are exhausting. The trolls really are specimens, aren't they!?
A mod that cost £4.99 that I wished I fitted years ago is wrapping a piece of 'astroturf' doormat around the side step/runners where the foot lands when getting in and out. Spending lots of time in muddy fields and ruts etc on farm shoots and foreshores (where it's useful to have lots of {roof}lighting after duck flights etc), the amount of mud one can scrape off boots before entering the vehicle is superb. The interior stays better/cleaner for longer.
A piece about the size of a wide A4 sheet held on with 3 cable ties does the job perfectly. D300 HSE 110
Post #108910 21st Dec 2011 3:02pm
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
Good idea that Ade Thumbs Up
Post #108915 21st Dec 2011 3:21pm
BigMike
Brendan, as far as I'm aware, ARB don't actually make a fridge, its branded ARB but is actually a Waeco (absent from your list). It's certainly made in the same premises as the Waeco fridges Thumbs Up
Post #108922 21st Dec 2011 4:48pm
leeds
Hi Mike, yes I did forget to mention the Waeco fridges, so apologies there.
Amended list in order of useful internal volume
WAECF-040AC £740 Gross capacity: approx. 37 litres
Now if we go onto things which are actually branded and the factory they come out of, we would be opening another complete can of worms. Just because different branded items come out of the same factory it does not mean that they are built with the same parts or to the same specifications.
Brendan
Post #108934 21st Dec 2011 6:42pm
I got a Waeco, though a maffise 80 litre Confused QRZ 2e0vpf
Post #108941 21st Dec 2011 6:48pm
