Home > Maintenance & Modifications > Change the brake disc
Eduardo
Hi there!
After 130.000 km my brake disk needs to be changed soon and the wheel hub needs the normal maintenance.
I would like to do that with an independant workshop (dealers workshop can be more than expensive) Main problem is when I see the workshop manual some Special tools are needed (LRT-54-0003; LRT-99-003; LRT54-019, LRT-99-503) to put the seals and a arm to put the comparison gauge and most than probably, the independant workshop dont have it.
I seen the cost of the tools in the WEB and are over GBP 300 that means a lot of money for somethigh to be use every 40,000 km.
¿Are those tools really necessary or is just to make the work easier?
Cheers! Eduardo
Post #108689 20th Dec 2011 2:39pm
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
No special tools needed to change brake discs or pads. You just need a DTI gauge to set the bearings in the hub up after but is can be done by feel if you dont have a DTI gauge.
Pete.
Post #108695 20th Dec 2011 2:57pm
jst
i have never used any special tools to change a brake disc or set up wheel bearings, you wont need them. there are plenty of how to do this items in the tech archive on LR4x4 if you are unsure. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #108738 20th Dec 2011 5:43pm
jst
http://forums.lr4x4.com/index.php?showtopic=29896 Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #108741 20th Dec 2011 5:45pm
Eduardo
Thanks to all!
So, no problem! Eduardo
Post #108753 20th Dec 2011 6:07pm
