![]() | Home > Td5 > rear bulkhead cab 90 |
Monstertuning Member Since: 11 Dec 2011 Location: Bridgnorth Posts: 8 ![]() |
any one have a photo of how a rear truck cab ie highcap rear bulkhead fits to a 90 inch www.monstertuning.co.uk
T1G UP Member Since: 08 Dec 2009 Location: Bath Posts: 3101 ![]() ![]() ![]() |
same as a rear tub, on the out riggers
on a 110 there are 4 brackets on outrigger and 2 straps that sit back , on a 90 the two furthest brackets fit but the two inside brakets are not there , the cab is also up in the air as the bottom brackets have nothing to sit on , land rover did fit this to 90 inch but im having no luck with a picture of the brackets installed . www.monstertuning.co.uk
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6214 ![]() ![]() ![]() |
Some pictures on Devon4x4 challenge truck story
marsie Member Since: 18 Nov 2011 Location: sheffieldish Posts: 535 ![]() ![]() ![]() |
There are 2 uprights on the tubular outriggers(2 bolts in each),the only other mounts on a 90 are on top of the a-frame crossmember inside the chassis rails that link to the underside of the seatbelt mounts on the rear bulkhead/tub
Paul |
